- To:
- Subject: Re: [cgal-discuss] fatal error: CGAL/Surface_mesh.h: No such file or directory
- Date: Wed, 20 Jan 2016 17:06:07 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:HK90GRIkn9RL+rbMmtmcpTZWNBhigK39O0sv0rFitYgULPrxwZ3uMQTl6Ol3ixeRBMOAu6wC0rKP+P+9EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35rxjrjrsMKOKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxcK08CLBZFz87KHsd5cvxtBCFQxHcyGEbVzBcqRdCChPZ7Rz8FrP2qCr9qqI99ySdOMDqV6EaUD++6L16CVWg3DwDMCQ4932Rj8hYg6dSoRbnrBt6ld2HKLqJPeZzK/uONegRQnBMC55c
The CGAL version you're using is probably too old. You need 4.7.
Sebastien.
On 01/20/2016 04:38 PM, Danyang Su wrote:
Hi Jane,
Sorry for the late reply. Thanks for your suggestion and it works if I
use an triangulated surface mesh.
Now i have another question regarding the surface mesh generation.
I got the following error when compile the demo codes. The code and make
command are attached.
#include <CGAL/Surface_mesh.h>
Is any compiling flags missing in the sh file?
Thanks and regards,
Danyang
On 16-01-04 11:45 PM, Jane Tournois wrote:
Hi Danyang,
your input polyhedron should be triangulated.
You can do this using the function
CGAL::Polygon_mesh_processing::triangulate_faces() [1]
I called it on your input and attach the triangulated version to this
email.
Your code works perfectly on it!
Regards,
Jane.
[1]
http://doc.cgal.org/latest/Polygon_mesh_processing/group__PkgPolygonMeshProcessing.html#ga78da163452ce0675288191bcab1dedc8
Le 03/01/2016 16:43, Danyang Su a écrit :
Hi All,
I am new to CGAL and has a question regarding 3D mesh generation from
a specific domain. The code file cgal_mesh.cc is attached with two
data files included. If I use fandisk.off data file as the domain, it
works fine. But if I use T3d_rec.off as the domain, it crashes with
error information as below.
terminate called after throwing an instance of
'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: !r_tr_.is_infinite(*cell_it)
File: /usr/include/CGAL/Mesh_3/Refine_cells_3.h
Line: 385
Aborted
The latter data file T3d_rec.off is just a simple hexahedron with
similar scale as fandisk.off.
Could anyone let me know what is wrong with the code, especially the
mesh criteria.
Thanks and regards,
Danyang
- [cgal-discuss] CGAL ERROR: assertion violation, Danyang Su, 01/03/2016
- Re: [cgal-discuss] CGAL ERROR: assertion violation, Jane Tournois, 01/04/2016
- [cgal-discuss] fatal error: CGAL/Surface_mesh.h: No such file or directory, Danyang Su, 01/20/2016
- Re: [cgal-discuss] fatal error: CGAL/Surface_mesh.h: No such file or directory, Sebastien Loriot (GeometryFactory), 01/20/2016
