cgal-discuss - Re: [cgal-discuss] Linear cell complex: facet membership query
  • To:
  • Subject: Re: [cgal-discuss] Linear cell complex: facet membership query
  • Date: Mon, 25 Jan 2016 12:59:46 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:yK9h+xFv+nOHhoJ0nfQmQZ1GYnF86YWxBRYc798ds5kLTJ75osSwAkXT6L1XgUPTWs2DsrQf27SQ6vm4Ejdbqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh770osSLKF4TzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzQrVcSTgnKGso/9bDtB/ZTALJ6GFPfH8Rl09nHgnB6BjnW5q5niL/t+N71GHOMtD3SbQ9RDGvqatiTR7hjisvMz8j8XqRgcpql+RVukTy9FRE34fIbdTNZ7JFdaTHcIZCSA==
Le 25/01/2016 12:35, Pranav a écrit :
Guillaume Damiand wrote
It is easy to modify the are_facets_same_geometry function to test if
two faces have the same geometry and the same orientation (replace 0 by
1).
If I want /are_facets_same_geometry/ function to compare only geometry and
disregard relative orientation of the input facets, do I need to modify it
to check for equality of points in both orientations, returning True if
points are same in either orientation?
Yes.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Linear-cell-complex-facet-membership-query-tp4661486p4661516.html
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.14.34 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
Attachment: smime.p7s
Description: Signature cryptographique S/MIME
