cgal-discuss - Re: [cgal-discuss] Multithreading, Contribution
  • To:
  • Cc: Bernhard Kornberger <>
  • Subject: Re: [cgal-discuss] Multithreading, Contribution
  • Date: Tue, 26 Jan 2016 11:06:34 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:anHILBAnVrYnsfaKPN8gUyQJP3N1i/DPJgcQr6AfoPdwSP7yo8bcNUDSrc9gkEXOFd2CrakU1ayP6vqrATNIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niabroseYO1oArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIZoGJ/3dKUgTLFeEC9ucyVsvJWq5lH/Sl6E6XIYF2kXiRFVGBPt7RfgX563vDGpmPB63XzQGcTrV70yRXyY7qFmQQKgyAwoHhp+32zQj8FslrN1qRm9oAZugsScNIWcKeBzeL+bZ9IcSGNcds1eXigHBZmzOdhcR9EdNPpV+tGu72AFqgGzUEz1XLvi
Dear Bernhard,
After almost a year, I am in the process of integrating your contribution
into
CGAL.
I am a few question, below, for the authors of the patch. How could I contact
them directly?
Le Wednesday 21 January 2015 12:06:03 Bernhard Kornberger a écrit :
> Hello!
> Last year researches from the Distributed and Parallel Systems Group
> of the University of Innsbruck have parallelized one of my programs.
> To this end they needed to patch CGAL to achieve thread safety for
> the Exact_predicates_exact_constructions_kernel. Now I'd like to
> contribute this patch and possibly start a discussion about it:
> http://www.geom.at/_downloads/patch.diff
> The patch is not my work, so I paste their description here:
Hi,
I am integrating a modified version of your patch in CGAL. That is the pull-
request 648 of CGAL/cgal on GitHub. You can see the patch here:
https://github.com/CGAL/cgal/pull/648/files
You can also pull my branch `Filtered_kernel-Epeck_reentrance-GF` from
https://github.com/lrineau/cgal
> ### Copy&Paste start ###
> The handler classes implement reference counting mechanisms. A simple
> atomic increment
> operation was added to the counter increment to avoid concurrent
> alteration. To provide portability,
> the boost::atomic tools were used, instead of using compiler dependent
> built/in functions.
> The current C++11 standard could have been used as well, std::atomic
> provides with the same functionality and portability.
> The modified files are: CGAL/Handle_for.h and CGAL/Handle.h
For that part, I have decided to use the C++11 atomics when available, then
fallback to Boost.Atomic, and only fallback to the non-documented
`boost::detail::atomic_count` when none of the other solutions are available.
> In CGAL/Lazy.h the version of the approx() method that is not constant
> and do returns a reference to the inner
> object was dropped. We want to avoid anyone from modify the state of the
> object so we can enforce thread
> safety. It seems that this method is not used during compilation and can
> be safely deleted.
I agree.
> The Lazy_rep object keeps two objects that hold the approximate value:
> at, that holds the
> original approximate value, and at_exact that holds the exact value that
> is recalculated inside
> update_exact. In this way, a thread that calls approx and ta thread that
> calls update_exact operate on
> different objects and we can ensure thread safety.
> Instead of utilizing a mutex to check whenever the approximate value has
> being updated, the
> check is done done via an atomic counter. This counter is initialized
> with value 0 to represent that
> the value is an approximation. The last statement of the update_exact
> operation updates the value to
> represent the fact that the value is no longer an approximation.
I do not understand your patch for `approx()`. I do not wee the atomic
variable that protects the value `this->at` from being access by a reader
while a writer thread is updating it from `exact()`.
I have added a lock of the mutex in `approx()` as well. Ideally, a shared
mutex should be used: locked "shared" in `approx()`, by reader threads, and
only locked with strict ownership in `exact()`, by a writer thread.
Laurent Rineau, PhD
  • Re: [cgal-discuss] Multithreading, Contribution, Laurent Rineau (CGAL/GeometryFactory), 01/26/2016
