cgal-discuss - [cgal-discuss] delaunay 2d triangulation/meshing with fixed points
  • To:
  • Subject: [cgal-discuss] delaunay 2d triangulation/meshing with fixed points
  • Date: Wed, 10 Feb 2016 10:52:27 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:MVqb5xUMR8sWQZ74UhHj3btJFC/V8LGtZVwlr6E/grcLSJyIuqrYZheHt8tkgFKBZ4jH8fUM07OQ6PC/Hzdaqs7c+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8KVOF8D3Gf1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdXBTBjP2Eu79DwrjHCSxGO7z0SSDY4iB1NVhLU8BDhFsP7rzno7PBl8CafNMzyC7szXGLxvO9QVBb0hXJfZHYC+2bNh5kogQ==
Hello,
I am a beginner with CGAL which I like very much so far. I think there is an issue (of documentation) with constrained Delaunay triangulation. The issue is below, but first, I want to describe the problem. If someone could indicate how solve my indexation problem, that would be nice too!
Problem:
I need to create a 2d mesh from "thin air" + boundaries (as if by Delaunay_mesher_2) but I must insert a few points which remain constant (that don't disappear or change their coordinates -- as if they were "punctual" constraints).
Issue:
Is it correct that,
A) refine_Delaunay_mesh_2 takes vertices as constants, so that, in particular, vertex_handles remain valid throughout the refinement procedure, and that no new vertices are added, whereas
B) Delaunay_mesher_2 invalidates vertex_handles, by possibly adding and/or removing some of them in the process of refinement?
So far this is what I tried to solve my problem:
1: insert boundary nodes and set boundary constraints,
2: run B) to generate a "new" triangulation
3: insert my "custom" vertices,
4: run A) (expecting that vertices remain constant)
I have to generate two types of output for nodes and links, respectively
ID,x,y
ID,ID
For that, I keep vertex handles in a map like this:
map<string,Vertex_handle> node_map;
this map is updated  after each step like so: node_map[ID]=Vertex_handle(Vertex_iterator);
which allows the retrieval of the vertex coordinates by their ID.
I noticed that during step 4 some of the vertex handles were not matched by an ID which makes me think that A) is incorrect (Help!) I checked that those vertices inserted at step 3 were still present though (Help....)
Thanks,
Rytis
