- To:
- Subject: Re: [cgal-discuss] delaunay 2d triangulation/meshing with fixed points
- Date: Wed, 24 Feb 2016 15:36:20 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:UuwMERD6kAiTTNy41ht5UyQJP3N1i/DPJgcQr6AfoPdwSP79o8bcNUDSrc9gkEXOFd2CrakU1KyL4+u+ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTokb3isMOLKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxcK08CLBZFz87KHsd5cvxtBCFQxHcyGEbVzBcqRdCChPZ7Rz8FrP2qCr9qqI99ySdOMDqV6EaUD++6L16CVWg3DwDMCQ4932Rj8hYg6dSoRbnrBt6ld2HKLqJPeZzK/uONegRQnBMC55c
Vertex handles inserted will remain valid in both scenarios
(refine_Delaunay_mesh_2 is using Delaunay_mesher_2 internally).
About the process, you can create your domain, insert your fixed points
and then only once the mesher.
Sebastien.
On 02/10/2016 10:52 AM, rytis wrote:
Hello,
I am a beginner with CGAL which I like very much so far. I think there
is an issue (of documentation) with constrained Delaunay triangulation.
The issue is below, but first, I want to describe the problem. If
someone could indicate how solve my indexation problem, that would be
nice too!
Problem:
I need to create a 2d mesh from "thin air" + boundaries (as if by
Delaunay_mesher_2) but I must insert a few points which remain constant
(that don't disappear or change their coordinates -- as if they were
"punctual" constraints).
Issue:
Is it correct that,
A) refine_Delaunay_mesh_2 takes vertices as constants, so that, in
particular, vertex_handles remain valid throughout the refinement
procedure, and that no new vertices are added, whereas
B) Delaunay_mesher_2 invalidates vertex_handles, by possibly adding
and/or removing some of them in the process of refinement?
So far this is what I tried to solve my problem:
1: insert boundary nodes and set boundary constraints,
2: run B) to generate a "new" triangulation
3: insert my "custom" vertices,
4: run A) (expecting that vertices remain constant)
I have to generate two types of output for nodes and links, respectively
ID,x,y
ID,ID
For that, I keep vertex handles in a map like this:
map<string,Vertex_handle> node_map;
this map is updated after each step like so:
node_map[ID]=Vertex_handle(Vertex_iterator);
which allows the retrieval of the vertex coordinates by their ID.
I noticed that during step 4 some of the vertex handles were not matched
by an ID which makes me think that A) is incorrect (Help!) I checked
that those vertices inserted at step 3 were still present though (Help....)
Thanks,
Rytis
- [cgal-discuss] delaunay 2d triangulation/meshing with fixed points, rytis, 02/10/2016
- Re: [cgal-discuss] delaunay 2d triangulation/meshing with fixed points, Sebastien Loriot (GeometryFactory), 02/24/2016
- Re: [cgal-discuss] delaunay 2d triangulation/meshing with fixed points, rytis, 02/26/2016
