- To: <>
- Subject: Re: [cgal-discuss] Mesh3 Polyhedral Domain
- Date: Fri, 12 Feb 2016 16:13:41 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:vJaGxxTt/SiKFWQF2GY3qSv2Itpsv+yvbD5Q0YIujvd0So/mwa65ZBGN2/xhgRfzUJnB7Loc0qyN4/+mAjJLv8bJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvipNuIPU4W1HKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQqIjULYNDCg6K3tno4rwpBzbRE2O4GEdWyMYiF1TEg3d5Vb7WJn29SD1v+441CiBNtDtVuMIXmH25KhiTFrkiTwMKiUi2GDRkM15yqxB9kGPvRt6lqfSbJuYK7JVZKTPfN4ADT5IWMpLWjMHCZm7fYoCFcIEMOpFqYjyvVIc6xKiU1r/TNjzwyNF0yellZYx1P4sRFnL
Hi Benjamin, Thanks very much for your fast reply! Would use of the 'Polygon soup' functions as described in the documentation (http://doc.cgal.org/latest/Polygon_mesh_processing/index.html#PolygonSoups) be a suitable preprocessing step to robustly account for this issue? Best wishes, Andrew On 11/02/16 20:19, Benjamin Kehlet
wrote:
Hi Andrew
The triangles in your files are not properly
oriented. This leads to triangles sharing
halfedges which is not allowed in a halfedge
based data structure. In fact all the triangles
in the plane z=2.5 should be flipped. See eg. On 11 February 2016 at 19:03, Andrew
Crozier <>
wrote:
Hi, I am using the 3D mesh generation code as part of my workflow for building finite element models of the heart, but have run into a bit of bother with one aspect of it. I am attempting to mesh a 3D polyhedral surface as in the example in the Mesh3 documentation: http://doc.cgal.org/latest/Mesh_3/index.html#Mesh_33DPolyhedralDomains When running this example, but only changing the input .off surface file to the attached 'slice.off' (and scaling the size parameters appropriately to correspond to the size of the input mesh), I get a segmentation fault in: Program received signal SIGSEGV, Segmentation fault. 0x0000000000494a60 in CGAL::Triangle_accessor_3<CGAL::Polyhedron_3<CGAL::Epick, CGAL::Polyhedron_items_3, CGAL::HalfedgeDS_default, std::allocator<int> >, CGAL::Epick>::triangle(CGAL::internal::In_place_list_const_iterator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > >, std::allocator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > > > > const&) const [clone .isra.1304] () However, when I run with the attached 'cube.off', I get no such error, and the mesh generates successfully. I suspect that there may be an issue with my input file, but having checked that the number of polys and points is correct, and that none of the polys contain out-of-range points, I am fairly stumped. If anyone here is able to have a look at my input files and/or suggest further action, I would appreciate it! Best wishes, Andrew Crozier -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://sympa.inria.fr/sympa/info/cgal-discuss |
- [cgal-discuss] Mesh3 Polyhedral Domain, Andrew Crozier, 02/11/2016
- Re: [cgal-discuss] Mesh3 Polyhedral Domain, Benjamin Kehlet, 02/11/2016
- Re: [cgal-discuss] Mesh3 Polyhedral Domain, Andrew Crozier, 02/12/2016
- Re: [cgal-discuss] Mesh3 Polyhedral Domain, Benjamin Kehlet, 02/12/2016
- Re: [cgal-discuss] Mesh3 Polyhedral Domain, Andrew Crozier, 02/15/2016
