cgal-discuss - [cgal-discuss] Mesh3 Polyhedral Domain
  • To: <>
  • Subject: [cgal-discuss] Mesh3 Polyhedral Domain
  • Date: Thu, 11 Feb 2016 19:03:32 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:LuM0NRBASvEPBvHTXbLnUyQJP3N1i/DPJgcQr6AfoPdwSP7+o8bcNUDSrc9gkEXOFd2CrakU1KyN7+u5ATVIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niKbpp9aKO1wArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9KvAzQrVcSTgnKGso/9bDtB/ZTALJ6GFKAUsMlR8dKg7J9hzlFrzrtTn7u/A1jCCcMdf7UvY/QzOw7qpxYBrlhDoBNjEj+XORg9Am3/ETmw6ouxEqm92cW4qSLvcrJq4=
Hi,
I am using the 3D mesh generation code as part of my workflow for building finite element models of the heart, but have run into a bit of bother with one aspect of it.
I am attempting to mesh a 3D polyhedral surface as in the example in the Mesh3 documentation:
http://doc.cgal.org/latest/Mesh_3/index.html#Mesh_33DPolyhedralDomains
When running this example, but only changing the input .off surface file to the attached 'slice.off' (and scaling the size parameters appropriately to correspond to the size of the input mesh), I get a segmentation fault in:
Program received signal SIGSEGV, Segmentation fault.
0x0000000000494a60 in CGAL::Triangle_accessor_3<CGAL::Polyhedron_3<CGAL::Epick, CGAL::Polyhedron_items_3, CGAL::HalfedgeDS_default, std::allocator<int> >, CGAL::Epick>::triangle(CGAL::internal::In_place_list_const_iterator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > >, std::allocator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>, std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Plane_3<CGAL::Epick> > > > > > const&) const [clone .isra.1304] ()
However, when I run with the attached 'cube.off', I get no such error, and the mesh generates successfully.
I suspect that there may be an issue with my input file, but having checked that the number of polys and points is correct, and that none of the polys contain out-of-range points, I am fairly stumped.
If anyone here is able to have a look at my input files and/or suggest further action, I would appreciate it!
Best wishes,
Andrew Crozier
OFF
8 12 24
10 -10 -10
10 -10 10
-10 -10 10
-10 -10 -10
10 10 -10
10 10 10
-10 10 10
-10 10 -10
3 0 1 2
3 0 2 3
3 4 7 6
3 4 6 5
3 0 4 5
3 0 5 1
3 1 5 6
3 1 6 2
3 2 6 7
3 2 7 3
3 4 0 3
3 4 3 7
OFF
988 1976 2964
169.661331177 162.160339355 -2.5
170.353057861 161.854049683 -2.5
171.13633728 161.640838623 -2.5
171.995071411 161.504196167 -2.5
172.913787842 161.427520752 -2.5
173.87828064 161.394699097 -2.5
174.875961304 161.390533447 -2.5
175.896270752 161.401596069 -2.5
176.930633545 161.416915894 -2.5
177.972183228 161.428695679 -2.5
179.015182495 161.432983398 -2.5
180.054260254 161.429840088 -2.5
181.083786011 161.423400879 -2.5
182.097244263 161.421295166 -2.5
183.087127686 161.433761597 -2.5
184.045166016 161.472412109 -2.5
184.963058472 161.548675537 -2.5
185.833450317 161.672271729 -2.5
186.651107788 161.84992981 -2.5
187.413879395 162.084350586 -2.5
168.357040405 162.85559082 -2.5
169.012252808 162.510604858 -2.5
188.123352051 162.373855591 -2.5
188.784896851 162.712539673 -2.5
189.407150269 163.091140747 -2.5
161.600006104 164.100006104 -2.5
162.353515625 163.853591919 -2.5
163.196762085 163.69694519 -2.5
164.098190308 163.598434448 -2.5
165.026092529 163.526306152 -2.5
165.948501587 163.448547363 -2.5
166.833023071 163.332702637 -2.5
167.646881104 163.146011353 -2.5
190.00100708 163.498260498 -2.5
190.578140259 163.921859741 -2.5
160.269729614 164.769699097 -2.5
160.913131714 164.413101196 -2.5
191.149536133 164.350860596 -2.5
191.724090576 164.776382446 -2.5
158.389953613 165.889953613 -2.5
159.019760132 165.519744873 -2.5
159.646453857 165.146438599 -2.5
192.307693481 165.192657471 -2.5
192.902755737 165.597412109 -2.5
193.508377075 165.991622925 -2.5
156.494750977 166.994766235 -2.5
157.125137329 166.625137329 -2.5
157.757827759 166.257827759 -2.5
194.120941162 166.378982544 -2.5
194.73500061 166.764907837 -2.5
195.344390869 167.155548096 -2.5
154.656646729 168.156646729 -2.5
155.256469727 167.756469727 -2.5
155.87046814 167.37046814 -2.5
195.943191528 167.556793213 -2.5
196.526535034 167.973480225 -2.5
153.509780884 169.009780884 -2.5
154.073898315 168.573898315 -2.5
197.091140747 168.408874512 -2.5
197.635528564 168.864486694 -2.5
152.436294556 169.936294556 -2.5
152.964309692 169.464309692 -2.5
198.160018921 169.339996338 -2.5
198.666427612 169.833557129 -2.5
199.15788269 170.34211731 -2.5
151.42539978 170.92539978 -2.5
151.923904419 170.423904419 -2.5
199.63822937 170.86177063 -2.5
150.466506958 171.966506958 -2.5
150.939651489 171.439651489 -2.5
200.11177063 171.38822937 -2.5
200.582748413 171.917251587 -2.5
149.561218262 173.061218262 -2.5
150.006622314 172.506622314 -2.5
173.954299927 172.997909546 -2.5
173.422195435 173.147003174 -2.5
174.490493774 172.987792969 -2.5
176.378204346 172.827056885 -2.5
175.684005737 172.931396484 -2.5
177.150054932 172.745315552 -2.5
177.968048096 172.704879761 -2.5
178.800598145 172.723937988 -2.5
179.615783691 172.819961548 -2.5
180.381088257 173.009887695 -2.5
201.055053711 172.444946289 -2.5
201.531814575 172.968185425 -2.5
148.719268799 174.219268799 -2.5
149.131713867 173.631698608 -2.5
172.881729126 173.400314331 -2.5
172.321166992 173.722930908 -2.5
175.057800293 173.003356934 -2.5
181.098876953 173.280822754 -2.5
181.771636963 173.619613647 -2.5
182.402664185 174.013000488 -2.5
202.015182495 173.484817505 -2.5
202.506118774 173.993881226 -2.5
148.324676514 174.824676514 -2.5
171.095672607 174.434585571 -2.5
170.431777954 174.787017822 -2.5
171.729385376 174.079559326 -2.5
182.996566772 174.447906494 -2.5
183.559555054 174.911819458 -2.5
203.004394531 174.49559021 -2.5
203.508560181 174.991439819 -2.5
147.589904785 176.089935303 -2.5
147.94821167 175.448242188 -2.5
168.373443604 175.832489014 -2.5
167.700424194 176.186706543 -2.5
169.059677124 175.484008789 -2.5
169.749359131 175.136489868 -2.5
184.09928894 175.393112183 -2.5
184.624649048 175.881347656 -2.5
204.016067505 175.483917236 -2.5
204.523529053 175.976455688 -2.5
147.249710083 176.749755859 -2.5
167.044509888 176.548812866 -2.5
166.407836914 176.921356201 -2.5
185.145050049 176.367385864 -2.5
185.669876099 176.843399048 -2.5
186.207946777 177.302688599 -2.5
205.026855469 176.473144531 -2.5
205.521514893 176.978500366 -2.5
146.625534058 178.125488281 -2.5
146.927963257 177.427978516 -2.5
165.190856934 177.704360962 -2.5
164.605255127 178.114425659 -2.5
165.790557861 177.30632019 -2.5
186.767227173 177.739318848 -2.5
206.0027771 177.497268677 -2.5
206.465942383 178.034118652 -2.5
146.344039917 178.843902588 -2.5
164.029342651 178.533966064 -2.5
163.458602905 178.959655762 -2.5
187.354873657 178.147766113 -2.5
187.977355957 178.522476196 -2.5
188.626174927 178.872161865 -2.5
206.906616211 178.593414307 -2.5
207.320953369 179.179016113 -2.5
145.853683472 180.353424072 -2.5
146.085830688 179.585586548 -2.5
162.889312744 179.388168335 -2.5
162.319229126 179.817169189 -2.5
189.292770386 179.205169678 -2.5
189.968734741 179.529495239 -2.5
190.645858765 179.852966309 -2.5
191.316116333 180.183334351 -2.5
207.705871582 179.793991089 -2.5
145.650695801 181.150543213 -2.5
161.177093506 180.675491333 -2.5
160.609832764 181.108917236 -2.5
161.747970581 180.245895386 -2.5
191.979766846 180.520278931 -2.5
192.637023926 180.863647461 -2.5
208.059234619 180.44052124 -2.5
208.379867554 181.119827271 -2.5
145.430328369 181.930541992 -2.5
160.05065918 181.550460815 -2.5
159.504623413 182.005126953 -2.5
193.287857056 181.2134552 -2.5
193.931808472 181.570037842 -2.5
194.567825317 181.934188843 -2.5
208.66758728 181.832229614 -2.5
145.146011353 182.646881104 -2.5
158.976760864 182.477935791 -2.5
158.471420288 182.973144531 -2.5
195.194061279 182.307342529 -2.5
195.807785034 182.691879272 -2.5
196.405380249 183.091308594 -2.5
208.92288208 182.577255249 -2.5
209.146789551 183.353897095 -2.5
144.284912109 183.787246704 -2.5
144.751113892 183.252838135 -2.5
157.991790771 183.493728638 -2.5
157.539520264 184.041015625 -2.5
196.982421875 183.510437012 -2.5
197.533843994 183.955307007 -2.5
209.340454102 184.160873413 -2.5
142.854949951 185.352157593 -2.5
143.296905518 184.79750061 -2.5
143.786911011 184.289077759 -2.5
157.114578247 184.614639282 -2.5
156.715179443 185.212661743 -2.5
198.054153442 184.433013916 -2.5
198.537612915 184.95123291 -2.5
209.515289307 184.986480713 -2.5
142.501159668 185.99307251 -2.5
156.338043213 185.832046509 -2.5
198.978469849 185.517608643 -2.5
199.371307373 186.138885498 -2.5
209.682647705 185.818969727 -2.5
142.222976685 186.708786011 -2.5
155.97869873 186.469024658 -2.5
155.632003784 187.119812012 -2.5
199.711196899 186.820068359 -2.5
209.853759766 186.646652222 -2.5
141.838394165 188.317962646 -2.5
142.006958008 187.48777771 -2.5
155.292755127 187.780975342 -2.5
199.994155884 187.56338501 -2.5
200.217544556 188.367645264 -2.5
210.040039062 187.457839966 -2.5
210.235687256 188.258468628 -2.5
141.701034546 189.186080933 -2.5
154.956359863 188.449829102 -2.5
154.619476318 189.124679565 -2.5
200.380432129 189.22769165 -2.5
210.435073853 189.054885864 -2.5
141.577209473 190.077102661 -2.5
154.280593872 189.804672241 -2.5
200.483978271 190.134246826 -2.5
210.632720947 189.854019165 -2.5
141.448150635 190.973800659 -2.5
153.940429688 190.489715576 -2.5
153.602142334 191.180145264 -2.5
200.531616211 191.074050903 -2.5
210.823364258 190.663284302 -2.5
141.294555664 191.856613159 -2.5
153.271286011 191.876373291 -2.5
200.529006958 192.030471802 -2.5
211.001953125 191.490066528 -2.5
211.163894653 192.3409729 -2.5
141.097137451 192.703857422 -2.5
152.955566406 192.578582764 -2.5
152.66456604 193.286560059 -2.5
200.483703613 192.984146118 -2.5
211.30519104 193.220779419 -2.5
140.549102783 194.235565186 -2.5
140.837097168 193.492156982 -2.5
152.409118652 193.999542236 -2.5
200.40473938 193.913833618 -2.5
211.422561646 194.131500244 -2.5
140.268585205 194.947555542 -2.5
152.200958252 194.716293335 -2.5
200.301925659 194.797195435 -2.5
211.513473511 195.071640015 -2.5
139.874893188 196.330841064 -2.5
140.031661987 195.641494751 -2.5
152.052322388 195.435165405 -2.5
151.975601196 196.154281616 -2.5
200.185287476 195.611465454 -2.5
211.576019287 196.036010742 -2.5
139.834976196 197.029144287 -2.5
151.98324585 196.871627808 -2.5
199.999984741 197.004455566 -2.5
200.064666748 196.333831787 -2.5
211.608810425 197.016159058 -2.5
139.913513184 197.718917847 -2.5
152.038406372 197.569274902 -2.5
152.07270813 198.237792969 -2.5
200.050888062 197.664016724 -2.5
200.145904541 198.353012085 -2.5
211.610839844 198.001251221 -2.5
140.111984253 198.382492065 -2.5
140.414703369 199.013275146 -2.5
152.017776489 198.867843628 -2.5
200.213882446 199.112670898 -2.5
211.581314087 198.979598999 -2.5
140.805557251 199.604232788 -2.5
151.805328369 199.450210571 -2.5
151.508605957 200.014541626 -2.5
200.246643066 199.923019409 -2.5
211.519790649 199.940063477 -2.5
141.267929077 200.148010254 -2.5
141.732131958 200.704864502 -2.5
142.128387451 201.334518433 -2.5
151.200820923 200.590438843 -2.5
150.955001831 201.207305908 -2.5
200.236877441 200.764434814 -2.5
211.42640686 200.873733521 -2.5
142.387161255 202.0962677 -2.5
150.844116211 201.89440918 -2.5
200.178146362 201.617370605 -2.5
211.302581787 201.775344849 -2.5
142.540344238 202.958053589 -2.5
150.843017578 202.63621521 -2.5
199.904754639 203.293548584 -2.5
200.064788818 202.461959839 -2.5
211.150177002 202.64276123 -2.5
142.618835449 203.889083862 -2.5
150.926849365 203.417282104 -2.5
151.059127808 204.235855103 -2.5
199.706192017 204.107315063 -2.5
210.969696045 203.47492981 -2.5
210.767822266 204.27897644 -2.5
142.651229858 204.861328125 -2.5
151.204147339 205.091369629 -2.5
199.463592529 204.888702393 -2.5
210.549697876 205.061599731 -2.5
142.662597656 205.850631714 -2.5
151.356903076 205.969299316 -2.5
199.170928955 205.623550415 -2.5
210.320465088 205.829986572 -2.5
142.67376709 206.837417603 -2.5
151.513656616 206.857345581 -2.5
198.423614502 206.91885376 -2.5
198.821350098 206.298202515 -2.5
210.086013794 206.591903687 -2.5
209.852325439 207.354766846 -2.5
142.701293945 207.806472778 -2.5
151.672195435 207.745544434 -2.5
197.516983032 208.029067993 -2.5
197.986038208 207.492858887 -2.5
209.625259399 208.125244141 -2.5
142.757995605 208.746170044 -2.5
151.83203125 208.626159668 -2.5
196.521148682 209.031005859 -2.5
197.025405884 208.537872314 -2.5
209.393569946 208.89225769 -2.5
142.854171753 209.647064209 -2.5
151.994354248 209.493286133 -2.5
152.149414062 210.356491089 -2.5
195.516845703 210.019271851 -2.5
196.014755249 209.520797729 -2.5
209.147262573 209.645645142 -2.5
142.998901367 210.500595093 -2.5
143.145843506 211.35295105 -2.5
152.288543701 211.226119995 -2.5
194.58366394 211.082092285 -2.5
195.037231445 210.537033081 -2.5
208.875091553 210.373779297 -2.5
208.573883057 211.073120117 -2.5
143.248703003 212.250045776 -2.5
152.43031311 212.08605957 -2.5
193.76914978 212.267669678 -2.5
194.160751343 211.658905029 -2.5
208.240463257 211.740219116 -2.5
143.328842163 213.170288086 -2.5
152.592941284 212.920776367 -2.5
193.404953003 212.90411377 -2.5
207.87512207 212.375228882 -2.5
207.481384277 212.981628418 -2.5
143.407608032 214.09197998 -2.5
152.793441772 213.715713501 -2.5
192.721481323 214.221450806 -2.5
193.059768677 213.559448242 -2.5
207.064819336 213.565063477 -2.5
206.63218689 214.132339478 -2.5
143.506652832 214.993347168 -2.5
153.046447754 214.458053589 -2.5
153.363220215 215.13760376 -2.5
192.376037598 214.876068115 -2.5
206.190383911 214.690444946 -2.5
205.74559021 215.245574951 -2.5
143.647903442 215.852294922 -2.5
153.750732422 215.747833252 -2.5
191.607070923 216.107162476 -2.5
192.009124756 215.509140015 -2.5
205.302536011 215.802490234 -2.5
143.853668213 216.646560669 -2.5
154.2109375 216.286712646 -2.5
154.740615845 216.757095337 -2.5
191.15687561 216.657241821 -2.5
204.864135742 216.364074707 -2.5
204.431411743 216.931396484 -2.5
144.146499634 217.353683472 -2.5
144.515670776 217.984405518 -2.5
155.331665039 217.166687012 -2.5
155.971939087 217.527297974 -2.5
156.646530151 217.853637695 -2.5
157.33921814 218.161804199 -2.5
189.413223267 217.914886475 -2.5
190.062164307 217.563583374 -2.5
190.646011353 217.146881104 -2.5
204.00378418 217.503768921 -2.5
203.579345703 218.079360962 -2.5
144.950286865 218.549713135 -2.5
145.439117432 219.060836792 -2.5
158.046478271 218.455215454 -2.5
158.765594482 218.736373901 -2.5
159.495193481 219.00642395 -2.5
185.539291382 219.029693604 -2.5
186.356719971 218.850357056 -2.5
187.166946411 218.663970947 -2.5
187.955108643 218.45475769 -2.5
188.707672119 218.208862305 -2.5
203.155563354 218.655563354 -2.5
202.729675293 219.229690552 -2.5
145.970718384 219.52923584 -2.5
146.533721924 219.9662323 -2.5
160.235305786 219.265060425 -2.5
160.98739624 219.510650635 -2.5
161.754211426 219.740615845 -2.5
162.539520264 219.951797485 -2.5
181.511550903 220.041244507 -2.5
182.298675537 219.809448242 -2.5
183.09715271 219.594863892 -2.5
183.905288696 219.396026611 -2.5
184.720535278 219.209381104 -2.5
202.299316406 219.799316406 -2.5
147.117370605 220.382614136 -2.5
147.712005615 220.787994385 -2.5
148.309646606 221.190368652 -2.5
163.347854614 220.140838623 -2.5
164.184112549 220.304351807 -2.5
165.041656494 220.451034546 -2.5
165.913574219 220.589538574 -2.5
166.792312622 220.728271484 -2.5
167.669464111 220.875152588 -2.5
168.53553772 221.037353516 -2.5
178.487045288 221.086074829 -2.5
179.224960327 220.818740845 -2.5
179.974578857 220.550476074 -2.5
180.736724854 220.289367676 -2.5
201.862701416 220.362701416 -2.5
201.418807983 220.918807983 -2.5
148.904388428 221.595611572 -2.5
149.492630005 222.007385254 -2.5
169.389968872 221.209671021 -2.5
170.231246948 221.385787964 -2.5
171.057113647 221.558303833 -2.5
171.864761353 221.718795776 -2.5
172.651092529 221.858139038 -2.5
173.412750244 221.966812134 -2.5
175.608078003 221.924926758 -2.5
176.32371521 221.774871826 -2.5
177.039352417 221.576278687 -2.5
177.75932312 221.342453003 -2.5
200.967208862 221.467208862 -2.5
200.507766724 222.007751465 -2.5
150.072921753 222.427078247 -2.5
150.645751953 222.854232788 -2.5
174.156097412 222.024993896 -2.5
174.887405396 222.0128479 -2.5
200.040176392 222.540176392 -2.5
199.563552856 223.063552856 -2.5
151.213088989 223.286895752 -2.5
151.777786255 223.722198486 -2.5
152.343078613 224.156936646 -2.5
199.076049805 223.576049805 -2.5
198.574798584 224.074798584 -2.5
152.912002563 224.588027954 -2.5
153.487091064 225.012954712 -2.5
198.056060791 224.556060791 -2.5
197.515731812 225.015731812 -2.5
154.070022583 225.430038452 -2.5
154.661560059 225.8384552 -2.5
196.950119019 225.450119019 -2.5
196.356765747 225.856750488 -2.5
155.261581421 226.238357544 -2.5
155.869216919 226.630615234 -2.5
156.483154297 227.016571045 -2.5
195.087265015 226.587280273 -2.5
194.417663574 226.917678833 -2.5
195.735153198 226.235137939 -2.5
157.101928711 227.397796631 -2.5
157.72416687 227.77571106 -2.5
158.348907471 228.151367188 -2.5
192.349533081 227.849563599 -2.5
191.665054321 228.165008545 -2.5
193.04095459 227.541015625 -2.5
193.732940674 227.23298645 -2.5
158.975631714 228.52520752 -2.5
159.604309082 228.897094727 -2.5
190.327926636 228.827682495 -2.5
189.67124939 229.170974731 -2.5
190.991165161 228.491027832 -2.5
160.235336304 229.266357422 -2.5
160.869354248 229.631973267 -2.5
161.507171631 229.992767334 -2.5
189.013183594 229.513046265 -2.5
188.342559814 229.84274292 -2.5
162.149765015 230.34765625 -2.5
162.798309326 230.695724487 -2.5
163.454452515 231.036117554 -2.5
185.352828979 230.854278564 -2.5
184.551742554 231.052047729 -2.5
186.142028809 230.643692017 -2.5
186.909591675 230.410873413 -2.5
187.646102905 230.146789551 -2.5
164.120483398 231.367965698 -2.5
164.799514771 231.689956665 -2.5
165.495452881 232.000061035 -2.5
181.330551147 231.818695068 -2.5
180.534133911 232.022155762 -2.5
182.131210327 231.622161865 -2.5
182.93649292 231.431167603 -2.5
183.744598389 231.242599487 -2.5
166.212768555 232.295257568 -2.5
166.955871582 232.571380615 -2.5
167.728515625 232.823181152 -2.5
168.532852173 233.044708252 -2.5
177.316070557 232.863922119 -2.5
176.477966309 233.054763794 -2.5
178.135818481 232.658340454 -2.5
178.941726685 232.445587158 -2.5
179.739334106 232.231994629 -2.5
169.368774414 233.229721069 -2.5
170.233520508 233.372497559 -2.5
171.121612549 233.46836853 -2.5
172.02532959 233.514480591 -2.5
172.935592651 233.510116577 -2.5
173.84312439 233.456985474 -2.5
174.7396698 233.359130859 -2.5
175.619064331 233.222564697 -2.5
169.661331177 162.160339355 2.5
170.353057861 161.854049683 2.5
171.13633728 161.640838623 2.5
171.995071411 161.504196167 2.5
172.913787842 161.427520752 2.5
173.87828064 161.394699097 2.5
174.875961304 161.390533447 2.5
175.896270752 161.401596069 2.5
176.930633545 161.416915894 2.5
177.972183228 161.428695679 2.5
179.015182495 161.432983398 2.5
180.054260254 161.429840088 2.5
181.083786011 161.423400879 2.5
182.097244263 161.421295166 2.5
183.087127686 161.433761597 2.5
184.045166016 161.472412109 2.5
184.963058472 161.548675537 2.5
185.833450317 161.672271729 2.5
186.651107788 161.84992981 2.5
187.413879395 162.084350586 2.5
168.357040405 162.85559082 2.5
169.012252808 162.510604858 2.5
188.123352051 162.373855591 2.5
188.784896851 162.712539673 2.5
189.407150269 163.091140747 2.5
161.600006104 164.100006104 2.5
162.353515625 163.853591919 2.5
163.196762085 163.69694519 2.5
164.098190308 163.598434448 2.5
165.026092529 163.526306152 2.5
165.948501587 163.448547363 2.5
166.833023071 163.332702637 2.5
167.646881104 163.146011353 2.5
190.00100708 163.498260498 2.5
190.578140259 163.921859741 2.5
160.269729614 164.769699097 2.5
160.913131714 164.413101196 2.5
191.149536133 164.350860596 2.5
191.724090576 164.776382446 2.5
158.389953613 165.889953613 2.5
159.019760132 165.519744873 2.5
159.646453857 165.146438599 2.5
192.307693481 165.192657471 2.5
192.902755737 165.597412109 2.5
193.508377075 165.991622925 2.5
156.494750977 166.994766235 2.5
157.125137329 166.625137329 2.5
157.757827759 166.257827759 2.5
194.120941162 166.378982544 2.5
194.73500061 166.764907837 2.5
195.344390869 167.155548096 2.5
154.656646729 168.156646729 2.5
155.256469727 167.756469727 2.5
155.87046814 167.37046814 2.5
195.943191528 167.556793213 2.5
196.526535034 167.973480225 2.5
153.509780884 169.009780884 2.5
154.073898315 168.573898315 2.5
197.091140747 168.408874512 2.5
197.635528564 168.864486694 2.5
152.436294556 169.936294556 2.5
152.964309692 169.464309692 2.5
198.160018921 169.339996338 2.5
198.666427612 169.833557129 2.5
199.15788269 170.34211731 2.5
151.42539978 170.92539978 2.5
151.923904419 170.423904419 2.5
199.63822937 170.86177063 2.5
150.466506958 171.966506958 2.5
150.939651489 171.439651489 2.5
200.11177063 171.38822937 2.5
200.582748413 171.917251587 2.5
149.561218262 173.061218262 2.5
150.006622314 172.506622314 2.5
173.954299927 172.997909546 2.5
173.422195435 173.147003174 2.5
174.490493774 172.987792969 2.5
176.378204346 172.827056885 2.5
175.684005737 172.931396484 2.5
177.150054932 172.745315552 2.5
177.968048096 172.704879761 2.5
178.800598145 172.723937988 2.5
179.615783691 172.819961548 2.5
180.381088257 173.009887695 2.5
201.055053711 172.444946289 2.5
201.531814575 172.968185425 2.5
148.719268799 174.219268799 2.5
149.131713867 173.631698608 2.5
172.881729126 173.400314331 2.5
172.321166992 173.722930908 2.5
175.057800293 173.003356934 2.5
181.098876953 173.280822754 2.5
181.771636963 173.619613647 2.5
182.402664185 174.013000488 2.5
202.015182495 173.484817505 2.5
202.506118774 173.993881226 2.5
148.324676514 174.824676514 2.5
171.095672607 174.434585571 2.5
170.431777954 174.787017822 2.5
171.729385376 174.079559326 2.5
182.996566772 174.447906494 2.5
183.559555054 174.911819458 2.5
203.004394531 174.49559021 2.5
203.508560181 174.991439819 2.5
147.589904785 176.089935303 2.5
147.94821167 175.448242188 2.5
168.373443604 175.832489014 2.5
167.700424194 176.186706543 2.5
169.059677124 175.484008789 2.5
169.749359131 175.136489868 2.5
184.09928894 175.393112183 2.5
184.624649048 175.881347656 2.5
204.016067505 175.483917236 2.5
204.523529053 175.976455688 2.5
147.249710083 176.749755859 2.5
167.044509888 176.548812866 2.5
166.407836914 176.921356201 2.5
185.145050049 176.367385864 2.5
185.669876099 176.843399048 2.5
186.207946777 177.302688599 2.5
205.026855469 176.473144531 2.5
205.521514893 176.978500366 2.5
146.625534058 178.125488281 2.5
146.927963257 177.427978516 2.5
165.190856934 177.704360962 2.5
164.605255127 178.114425659 2.5
165.790557861 177.30632019 2.5
186.767227173 177.739318848 2.5
206.0027771 177.497268677 2.5
206.465942383 178.034118652 2.5
146.344039917 178.843902588 2.5
164.029342651 178.533966064 2.5
163.458602905 178.959655762 2.5
187.354873657 178.147766113 2.5
187.977355957 178.522476196 2.5
188.626174927 178.872161865 2.5
206.906616211 178.593414307 2.5
207.320953369 179.179016113 2.5
145.853683472 180.353424072 2.5
146.085830688 179.585586548 2.5
162.889312744 179.388168335 2.5
162.319229126 179.817169189 2.5
189.292770386 179.205169678 2.5
189.968734741 179.529495239 2.5
190.645858765 179.852966309 2.5
191.316116333 180.183334351 2.5
207.705871582 179.793991089 2.5
145.650695801 181.150543213 2.5
161.177093506 180.675491333 2.5
160.609832764 181.108917236 2.5
161.747970581 180.245895386 2.5
191.979766846 180.520278931 2.5
192.637023926 180.863647461 2.5
208.059234619 180.44052124 2.5
208.379867554 181.119827271 2.5
145.430328369 181.930541992 2.5
160.05065918 181.550460815 2.5
159.504623413 182.005126953 2.5
193.287857056 181.2134552 2.5
193.931808472 181.570037842 2.5
194.567825317 181.934188843 2.5
208.66758728 181.832229614 2.5
145.146011353 182.646881104 2.5
158.976760864 182.477935791 2.5
158.471420288 182.973144531 2.5
195.194061279 182.307342529 2.5
195.807785034 182.691879272 2.5
196.405380249 183.091308594 2.5
208.92288208 182.577255249 2.5
209.146789551 183.353897095 2.5
144.284912109 183.787246704 2.5
144.751113892 183.252838135 2.5
157.991790771 183.493728638 2.5
157.539520264 184.041015625 2.5
196.982421875 183.510437012 2.5
197.533843994 183.955307007 2.5
209.340454102 184.160873413 2.5
142.854949951 185.352157593 2.5
143.296905518 184.79750061 2.5
143.786911011 184.289077759 2.5
157.114578247 184.614639282 2.5
156.715179443 185.212661743 2.5
198.054153442 184.433013916 2.5
198.537612915 184.95123291 2.5
209.515289307 184.986480713 2.5
142.501159668 185.99307251 2.5
156.338043213 185.832046509 2.5
198.978469849 185.517608643 2.5
199.371307373 186.138885498 2.5
209.682647705 185.818969727 2.5
142.222976685 186.708786011 2.5
155.97869873 186.469024658 2.5
155.632003784 187.119812012 2.5
199.711196899 186.820068359 2.5
209.853759766 186.646652222 2.5
141.838394165 188.317962646 2.5
142.006958008 187.48777771 2.5
155.292755127 187.780975342 2.5
199.994155884 187.56338501 2.5
200.217544556 188.367645264 2.5
210.040039062 187.457839966 2.5
210.235687256 188.258468628 2.5
141.701034546 189.186080933 2.5
154.956359863 188.449829102 2.5
154.619476318 189.124679565 2.5
200.380432129 189.22769165 2.5
210.435073853 189.054885864 2.5
141.577209473 190.077102661 2.5
154.280593872 189.804672241 2.5
200.483978271 190.134246826 2.5
210.632720947 189.854019165 2.5
141.448150635 190.973800659 2.5
153.940429688 190.489715576 2.5
153.602142334 191.180145264 2.5
200.531616211 191.074050903 2.5
210.823364258 190.663284302 2.5
141.294555664 191.856613159 2.5
153.271286011 191.876373291 2.5
200.529006958 192.030471802 2.5
211.001953125 191.490066528 2.5
211.163894653 192.3409729 2.5
141.097137451 192.703857422 2.5
152.955566406 192.578582764 2.5
152.66456604 193.286560059 2.5
200.483703613 192.984146118 2.5
211.30519104 193.220779419 2.5
140.549102783 194.235565186 2.5
140.837097168 193.492156982 2.5
152.409118652 193.999542236 2.5
200.40473938 193.913833618 2.5
211.422561646 194.131500244 2.5
140.268585205 194.947555542 2.5
152.200958252 194.716293335 2.5
200.301925659 194.797195435 2.5
211.513473511 195.071640015 2.5
139.874893188 196.330841064 2.5
140.031661987 195.641494751 2.5
152.052322388 195.435165405 2.5
151.975601196 196.154281616 2.5
200.185287476 195.611465454 2.5
211.576019287 196.036010742 2.5
139.834976196 197.029144287 2.5
151.98324585 196.871627808 2.5
199.999984741 197.004455566 2.5
200.064666748 196.333831787 2.5
211.608810425 197.016159058 2.5
139.913513184 197.718917847 2.5
152.038406372 197.569274902 2.5
152.07270813 198.237792969 2.5
200.050888062 197.664016724 2.5
200.145904541 198.353012085 2.5
211.610839844 198.001251221 2.5
140.111984253 198.382492065 2.5
140.414703369 199.013275146 2.5
152.017776489 198.867843628 2.5
200.213882446 199.112670898 2.5
211.581314087 198.979598999 2.5
140.805557251 199.604232788 2.5
151.805328369 199.450210571 2.5
151.508605957 200.014541626 2.5
200.246643066 199.923019409 2.5
211.519790649 199.940063477 2.5
141.267929077 200.148010254 2.5
141.732131958 200.704864502 2.5
142.128387451 201.334518433 2.5
151.200820923 200.590438843 2.5
150.955001831 201.207305908 2.5
200.236877441 200.764434814 2.5
211.42640686 200.873733521 2.5
142.387161255 202.0962677 2.5
150.844116211 201.89440918 2.5
200.178146362 201.617370605 2.5
211.302581787 201.775344849 2.5
142.540344238 202.958053589 2.5
150.843017578 202.63621521 2.5
199.904754639 203.293548584 2.5
200.064788818 202.461959839 2.5
211.150177002 202.64276123 2.5
142.618835449 203.889083862 2.5
150.926849365 203.417282104 2.5
151.059127808 204.235855103 2.5
199.706192017 204.107315063 2.5
210.969696045 203.47492981 2.5
210.767822266 204.27897644 2.5
142.651229858 204.861328125 2.5
151.204147339 205.091369629 2.5
199.463592529 204.888702393 2.5
210.549697876 205.061599731 2.5
142.662597656 205.850631714 2.5
151.356903076 205.969299316 2.5
199.170928955 205.623550415 2.5
210.320465088 205.829986572 2.5
142.67376709 206.837417603 2.5
151.513656616 206.857345581 2.5
198.423614502 206.91885376 2.5
198.821350098 206.298202515 2.5
210.086013794 206.591903687 2.5
209.852325439 207.354766846 2.5
142.701293945 207.806472778 2.5
151.672195435 207.745544434 2.5
197.516983032 208.029067993 2.5
197.986038208 207.492858887 2.5
209.625259399 208.125244141 2.5
142.757995605 208.746170044 2.5
151.83203125 208.626159668 2.5
196.521148682 209.031005859 2.5
197.025405884 208.537872314 2.5
209.393569946 208.89225769 2.5
142.854171753 209.647064209 2.5
151.994354248 209.493286133 2.5
152.149414062 210.356491089 2.5
195.516845703 210.019271851 2.5
196.014755249 209.520797729 2.5
209.147262573 209.645645142 2.5
142.998901367 210.500595093 2.5
143.145843506 211.35295105 2.5
152.288543701 211.226119995 2.5
194.58366394 211.082092285 2.5
195.037231445 210.537033081 2.5
208.875091553 210.373779297 2.5
208.573883057 211.073120117 2.5
143.248703003 212.250045776 2.5
152.43031311 212.08605957 2.5
193.76914978 212.267669678 2.5
194.160751343 211.658905029 2.5
208.240463257 211.740219116 2.5
143.328842163 213.170288086 2.5
152.592941284 212.920776367 2.5
193.404953003 212.90411377 2.5
207.87512207 212.375228882 2.5
207.481384277 212.981628418 2.5
143.407608032 214.09197998 2.5
152.793441772 213.715713501 2.5
192.721481323 214.221450806 2.5
193.059768677 213.559448242 2.5
207.064819336 213.565063477 2.5
206.63218689 214.132339478 2.5
143.506652832 214.993347168 2.5
153.046447754 214.458053589 2.5
153.363220215 215.13760376 2.5
192.376037598 214.876068115 2.5
206.190383911 214.690444946 2.5
205.74559021 215.245574951 2.5
143.647903442 215.852294922 2.5
153.750732422 215.747833252 2.5
191.607070923 216.107162476 2.5
192.009124756 215.509140015 2.5
205.302536011 215.802490234 2.5
143.853668213 216.646560669 2.5
154.2109375 216.286712646 2.5
154.740615845 216.757095337 2.5
191.15687561 216.657241821 2.5
204.864135742 216.364074707 2.5
204.431411743 216.931396484 2.5
144.146499634 217.353683472 2.5
144.515670776 217.984405518 2.5
155.331665039 217.166687012 2.5
155.971939087 217.527297974 2.5
156.646530151 217.853637695 2.5
157.33921814 218.161804199 2.5
189.413223267 217.914886475 2.5
190.062164307 217.563583374 2.5
190.646011353 217.146881104 2.5
204.00378418 217.503768921 2.5
203.579345703 218.079360962 2.5
144.950286865 218.549713135 2.5
145.439117432 219.060836792 2.5
158.046478271 218.455215454 2.5
158.765594482 218.736373901 2.5
159.495193481 219.00642395 2.5
185.539291382 219.029693604 2.5
186.356719971 218.850357056 2.5
187.166946411 218.663970947 2.5
187.955108643 218.45475769 2.5
188.707672119 218.208862305 2.5
203.155563354 218.655563354 2.5
202.729675293 219.229690552 2.5
145.970718384 219.52923584 2.5
146.533721924 219.9662323 2.5
160.235305786 219.265060425 2.5
160.98739624 219.510650635 2.5
161.754211426 219.740615845 2.5
162.539520264 219.951797485 2.5
181.511550903 220.041244507 2.5
182.298675537 219.809448242 2.5
183.09715271 219.594863892 2.5
183.905288696 219.396026611 2.5
184.720535278 219.209381104 2.5
202.299316406 219.799316406 2.5
147.117370605 220.382614136 2.5
147.712005615 220.787994385 2.5
148.309646606 221.190368652 2.5
163.347854614 220.140838623 2.5
164.184112549 220.304351807 2.5
165.041656494 220.451034546 2.5
165.913574219 220.589538574 2.5
166.792312622 220.728271484 2.5
167.669464111 220.875152588 2.5
168.53553772 221.037353516 2.5
178.487045288 221.086074829 2.5
179.224960327 220.818740845 2.5
179.974578857 220.550476074 2.5
180.736724854 220.289367676 2.5
201.862701416 220.362701416 2.5
201.418807983 220.918807983 2.5
148.904388428 221.595611572 2.5
149.492630005 222.007385254 2.5
169.389968872 221.209671021 2.5
170.231246948 221.385787964 2.5
171.057113647 221.558303833 2.5
171.864761353 221.718795776 2.5
172.651092529 221.858139038 2.5
173.412750244 221.966812134 2.5
175.608078003 221.924926758 2.5
176.32371521 221.774871826 2.5
177.039352417 221.576278687 2.5
177.75932312 221.342453003 2.5
200.967208862 221.467208862 2.5
200.507766724 222.007751465 2.5
150.072921753 222.427078247 2.5
150.645751953 222.854232788 2.5
174.156097412 222.024993896 2.5
174.887405396 222.0128479 2.5
200.040176392 222.540176392 2.5
199.563552856 223.063552856 2.5
151.213088989 223.286895752 2.5
151.777786255 223.722198486 2.5
152.343078613 224.156936646 2.5
199.076049805 223.576049805 2.5
198.574798584 224.074798584 2.5
152.912002563 224.588027954 2.5
153.487091064 225.012954712 2.5
198.056060791 224.556060791 2.5
197.515731812 225.015731812 2.5
154.070022583 225.430038452 2.5
154.661560059 225.8384552 2.5
196.950119019 225.450119019 2.5
196.356765747 225.856750488 2.5
155.261581421 226.238357544 2.5
155.869216919 226.630615234 2.5
156.483154297 227.016571045 2.5
195.087265015 226.587280273 2.5
194.417663574 226.917678833 2.5
195.735153198 226.235137939 2.5
157.101928711 227.397796631 2.5
157.72416687 227.77571106 2.5
158.348907471 228.151367188 2.5
192.349533081 227.849563599 2.5
191.665054321 228.165008545 2.5
193.04095459 227.541015625 2.5
193.732940674 227.23298645 2.5
158.975631714 228.52520752 2.5
159.604309082 228.897094727 2.5
190.327926636 228.827682495 2.5
189.67124939 229.170974731 2.5
190.991165161 228.491027832 2.5
160.235336304 229.266357422 2.5
160.869354248 229.631973267 2.5
161.507171631 229.992767334 2.5
189.013183594 229.513046265 2.5
188.342559814 229.84274292 2.5
162.149765015 230.34765625 2.5
162.798309326 230.695724487 2.5
163.454452515 231.036117554 2.5
185.352828979 230.854278564 2.5
184.551742554 231.052047729 2.5
186.142028809 230.643692017 2.5
186.909591675 230.410873413 2.5
187.646102905 230.146789551 2.5
164.120483398 231.367965698 2.5
164.799514771 231.689956665 2.5
165.495452881 232.000061035 2.5
181.330551147 231.818695068 2.5
180.534133911 232.022155762 2.5
182.131210327 231.622161865 2.5
182.93649292 231.431167603 2.5
183.744598389 231.242599487 2.5
166.212768555 232.295257568 2.5
166.955871582 232.571380615 2.5
167.728515625 232.823181152 2.5
168.532852173 233.044708252 2.5
177.316070557 232.863922119 2.5
176.477966309 233.054763794 2.5
178.135818481 232.658340454 2.5
178.941726685 232.445587158 2.5
179.739334106 232.231994629 2.5
169.368774414 233.229721069 2.5
170.233520508 233.372497559 2.5
171.121612549 233.46836853 2.5
172.02532959 233.514480591 2.5
172.935592651 233.510116577 2.5
173.84312439 233.456985474 2.5
174.7396698 233.359130859 2.5
175.619064331 233.222564697 2.5
3 0 1 494
3 495 494 1
3 1 2 495
3 495 2 496
3 2 3 496
3 497 496 3
3 3 4 497
3 498 497 4
3 4 5 498
3 499 498 5
3 5 6 499
3 500 499 6
3 6 7 500
3 501 500 7
3 7 8 501
3 502 501 8
3 8 9 502
3 503 502 9
3 9 10 503
3 504 503 10
3 10 11 504
3 505 504 11
3 11 12 505
3 506 505 12
3 12 13 506
3 507 506 13
3 13 14 507
3 508 507 14
3 14 15 508
3 509 508 15
3 15 16 509
3 510 509 16
3 16 17 510
3 511 510 17
3 17 18 511
3 512 511 18
3 18 19 512
3 513 512 19
3 19 22 513
3 22 516 513
3 22 23 516
3 517 516 23
3 23 24 517
3 518 517 24
3 24 33 518
3 527 518 33
3 33 34 527
3 528 527 34
3 34 37 528
3 531 528 37
3 37 38 531
3 532 531 38
3 38 42 532
3 536 532 42
3 42 43 536
3 43 537 536
3 43 44 537
3 538 537 44
3 44 48 538
3 542 538 48
3 48 49 542
3 543 542 49
3 49 50 543
3 544 543 50
3 50 54 544
3 548 544 54
3 54 55 548
3 55 549 548
3 55 58 549
3 552 549 58
3 58 59 552
3 553 552 59
3 59 62 553
3 556 553 62
3 62 63 556
3 557 556 63
3 63 64 557
3 558 557 64
3 64 67 558
3 561 558 67
3 67 70 561
3 70 564 561
3 70 71 564
3 565 564 71
3 71 84 565
3 578 565 84
3 84 85 578
3 579 578 85
3 85 94 579
3 94 588 579
3 94 95 588
3 95 589 588
3 95 102 589
3 596 589 102
3 102 103 596
3 597 596 103
3 103 112 597
3 606 597 112
3 112 113 606
3 113 607 606
3 113 120 607
3 614 607 120
3 120 121 614
3 615 614 121
3 121 128 615
3 622 615 128
3 128 129 622
3 623 622 129
3 129 136 623
3 630 623 136
3 136 137 630
3 631 630 137
3 137 146 631
3 640 631 146
3 146 153 640
3 647 640 153
3 153 154 647
3 648 647 154
3 154 161 648
3 655 648 161
3 161 168 655
3 662 655 168
3 168 169 662
3 663 662 169
3 169 176 663
3 176 670 663
3 176 184 670
3 678 670 184
3 184 189 678
3 683 678 189
3 189 194 683
3 688 683 194
3 194 200 688
3 200 694 688
3 200 201 694
3 695 694 201
3 201 206 695
3 700 695 206
3 206 210 700
3 210 704 700
3 210 215 704
3 709 704 215
3 215 219 709
3 713 709 219
3 219 220 713
3 714 713 220
3 220 225 714
3 225 719 714
3 225 230 719
3 724 719 230
3 230 234 724
3 728 724 234
3 234 240 728
3 734 728 240
3 240 245 734
3 739 734 245
3 245 251 739
3 745 739 251
3 251 256 745
3 750 745 256
3 256 261 750
3 755 750 261
3 261 268 755
3 762 755 268
3 268 272 762
3 766 762 272
3 272 277 766
3 771 766 277
3 277 282 771
3 776 771 282
3 282 283 776
3 777 776 283
3 283 287 777
3 287 781 777
3 287 291 781
3 785 781 291
3 291 296 785
3 790 785 296
3 296 297 790
3 791 790 297
3 297 302 791
3 796 791 302
3 302 307 796
3 801 796 307
3 307 313 801
3 807 801 313
3 313 319 807
3 319 813 807
3 319 320 813
3 814 813 320
3 320 325 814
3 819 814 325
3 325 329 819
3 823 819 329
3 329 330 823
3 824 823 330
3 330 335 824
3 829 824 335
3 335 336 829
3 830 829 336
3 336 341 830
3 835 830 341
3 341 342 835
3 836 835 342
3 342 347 836
3 841 836 347
3 347 352 841
3 846 841 352
3 352 353 846
3 847 846 353
3 353 363 847
3 857 847 363
3 363 364 857
3 858 857 364
3 364 375 858
3 869 858 375
3 375 376 869
3 870 869 376
3 376 388 870
3 388 882 870
3 388 403 882
3 403 897 882
3 403 404 897
3 898 897 404
3 404 417 898
3 911 898 417
3 417 418 911
3 912 911 418
3 418 423 912
3 423 917 912
3 423 424 917
3 918 917 424
3 424 428 918
3 922 918 428
3 428 429 922
3 923 922 429
3 429 432 923
3 432 926 923
3 432 433 926
3 433 927 926
3 433 436 927
3 436 930 927
3 436 437 930
3 931 930 437
3 437 443 931
3 937 931 443
3 443 441 937
3 935 937 441
3 441 442 935
3 442 936 935
3 442 450 936
3 944 936 450
3 450 449 944
3 449 943 944
3 449 447 943
3 941 943 447
3 447 448 941
3 942 941 448
3 448 455 942
3 949 942 455
3 455 453 949
3 947 949 453
3 453 454 947
3 948 947 454
3 454 459 948
3 953 948 459
3 459 460 953
3 954 953 460
3 460 468 954
3 962 954 468
3 468 467 962
3 961 962 467
3 467 466 961
3 960 961 466
3 466 464 960
3 958 960 464
3 464 465 958
3 959 958 465
3 465 476 959
3 970 959 476
3 476 475 970
3 475 969 970
3 475 474 969
3 968 969 474
3 474 472 968
3 472 966 968
3 472 473 966
3 967 966 473
3 473 485 967
3 979 967 485
3 485 484 979
3 978 979 484
3 484 483 978
3 483 977 978
3 483 481 977
3 975 977 481
3 481 482 975
3 976 975 482
3 482 493 976
3 987 976 493
3 493 492 987
3 492 986 987
3 492 491 986
3 985 986 491
3 491 490 985
3 984 985 490
3 490 489 984
3 983 984 489
3 489 488 983
3 982 983 488
3 488 487 982
3 981 982 487
3 487 486 981
3 486 980 981
3 486 480 980
3 974 980 480
3 480 479 974
3 973 974 479
3 479 478 973
3 972 973 478
3 478 477 972
3 971 972 477
3 477 471 971
3 965 971 471
3 471 470 965
3 470 964 965
3 470 469 964
3 963 964 469
3 469 463 963
3 957 963 463
3 463 462 957
3 956 957 462
3 462 461 956
3 461 955 956
3 461 458 955
3 952 955 458
3 458 457 952
3 951 952 457
3 457 456 951
3 950 951 456
3 456 452 950
3 946 950 452
3 452 451 946
3 451 945 946
3 451 446 945
3 940 945 446
3 446 445 940
3 939 940 445
3 445 444 939
3 938 939 444
3 444 440 938
3 440 934 938
3 440 439 934
3 933 934 439
3 439 438 933
3 932 933 438
3 438 435 932
3 929 932 435
3 435 434 929
3 928 929 434
3 434 431 928
3 925 928 431
3 431 430 925
3 924 925 430
3 430 427 924
3 921 924 427
3 427 426 921
3 426 920 921
3 426 425 920
3 425 919 920
3 425 420 919
3 914 919 420
3 420 419 914
3 913 914 419
3 419 406 913
3 900 913 406
3 406 405 900
3 899 900 405
3 405 391 899
3 885 899 391
3 391 390 885
3 884 885 390
3 390 389 884
3 883 884 389
3 389 378 883
3 872 883 378
3 378 377 872
3 377 871 872
3 377 366 871
3 860 871 366
3 366 365 860
3 859 860 365
3 365 355 859
3 849 859 355
3 355 354 849
3 354 848 849
3 354 348 848
3 842 848 348
3 348 343 842
3 837 842 343
3 343 337 837
3 831 837 337
3 337 331 831
3 825 831 331
3 331 326 825
3 820 825 326
3 326 321 820
3 815 820 321
3 321 315 815
3 809 815 315
3 315 314 809
3 808 809 314
3 314 308 808
3 802 808 308
3 308 303 802
3 797 802 303
3 303 298 797
3 792 797 298
3 298 292 792
3 786 792 292
3 292 288 786
3 782 786 288
3 288 284 782
3 778 782 284
3 284 278 778
3 772 778 278
3 278 273 772
3 767 772 273
3 273 269 767
3 763 767 269
3 269 264 763
3 758 763 264
3 264 263 758
3 757 758 263
3 263 262 757
3 756 757 262
3 262 257 756
3 257 751 756
3 257 253 751
3 747 751 253
3 253 252 747
3 746 747 252
3 252 246 746
3 740 746 246
3 246 241 740
3 735 740 241
3 241 235 735
3 729 735 235
3 235 236 729
3 730 729 236
3 236 231 730
3 725 730 231
3 231 226 725
3 720 725 226
3 226 227 720
3 721 720 227
3 227 221 721
3 715 721 221
3 221 216 715
3 710 715 216
3 216 211 710
3 705 710 211
3 211 207 705
3 207 701 705
3 207 202 701
3 696 701 202
3 202 195 696
3 195 689 696
3 195 196 689
3 690 689 196
3 196 190 690
3 190 684 690
3 190 185 684
3 679 684 185
3 185 177 679
3 671 679 177
3 177 178 671
3 672 671 178
3 178 179 672
3 673 672 179
3 179 170 673
3 664 673 170
3 170 171 664
3 665 664 171
3 171 162 665
3 162 656 665
3 162 155 656
3 649 656 155
3 155 147 649
3 641 649 147
3 147 138 641
3 632 641 138
3 138 139 632
3 633 632 139
3 139 130 633
3 130 624 633
3 130 122 624
3 122 616 624
3 122 123 616
3 617 616 123
3 123 114 617
3 608 617 114
3 114 104 608
3 598 608 104
3 104 105 598
3 599 598 105
3 105 96 599
3 96 590 599
3 96 86 590
3 86 580 590
3 86 87 580
3 581 580 87
3 87 72 581
3 566 581 72
3 72 73 566
3 73 567 566
3 73 68 567
3 562 567 68
3 68 69 562
3 563 562 69
3 69 65 563
3 559 563 65
3 65 66 559
3 560 559 66
3 66 60 560
3 554 560 60
3 60 61 554
3 555 554 61
3 61 56 555
3 550 555 56
3 56 57 550
3 57 551 550
3 57 51 551
3 545 551 51
3 51 52 545
3 546 545 52
3 52 53 546
3 547 546 53
3 53 45 547
3 539 547 45
3 45 46 539
3 46 540 539
3 46 47 540
3 541 540 47
3 47 39 541
3 533 541 39
3 39 40 533
3 534 533 40
3 40 41 534
3 535 534 41
3 41 35 535
3 529 535 35
3 35 36 529
3 530 529 36
3 36 25 530
3 519 530 25
3 25 26 519
3 520 519 26
3 26 27 520
3 521 520 27
3 27 28 521
3 522 521 28
3 28 29 522
3 523 522 29
3 29 30 523
3 524 523 30
3 30 31 524
3 524 31 525
3 31 32 525
3 526 525 32
3 32 20 526
3 514 526 20
3 20 21 514
3 515 514 21
3 21 0 515
3 494 515 0
3 74 75 568
3 569 568 75
3 75 88 569
3 88 582 569
3 88 89 582
3 583 582 89
3 89 99 583
3 593 583 99
3 99 97 593
3 591 593 97
3 97 98 591
3 592 591 98
3 98 109 592
3 603 592 109
3 109 108 603
3 602 603 108
3 108 106 602
3 600 602 106
3 106 107 600
3 107 601 600
3 107 115 601
3 609 601 115
3 115 116 609
3 610 609 116
3 116 126 610
3 126 620 610
3 126 124 620
3 618 620 124
3 124 125 618
3 619 618 125
3 125 131 619
3 625 619 131
3 131 132 625
3 626 625 132
3 132 140 626
3 634 626 140
3 140 141 634
3 635 634 141
3 141 150 635
3 635 150 644
3 150 148 644
3 642 644 148
3 148 149 642
3 643 642 149
3 149 156 643
3 156 650 643
3 156 157 650
3 651 650 157
3 157 163 651
3 657 651 163
3 163 164 657
3 658 657 164
3 164 172 658
3 666 658 172
3 172 173 666
3 667 666 173
3 173 180 667
3 674 667 180
3 180 181 674
3 181 675 674
3 181 186 675
3 680 675 186
3 186 191 680
3 685 680 191
3 191 192 685
3 192 686 685
3 192 197 686
3 691 686 197
3 197 203 691
3 697 691 203
3 203 204 697
3 698 697 204
3 204 208 698
3 208 702 698
3 208 212 702
3 212 706 702
3 212 213 706
3 707 706 213
3 213 217 707
3 217 711 707
3 217 222 711
3 716 711 222
3 222 223 716
3 717 716 223
3 223 228 717
3 722 717 228
3 228 232 722
3 726 722 232
3 232 237 726
3 731 726 237
3 237 238 731
3 732 731 238
3 238 242 732
3 242 736 732
3 242 247 736
3 247 741 736
3 247 248 741
3 742 741 248
3 248 254 742
3 748 742 254
3 254 258 748
3 258 752 748
3 258 259 752
3 753 752 259
3 259 265 753
3 265 759 753
3 265 266 759
3 760 759 266
3 266 270 760
3 764 760 270
3 270 274 764
3 768 764 274
3 274 279 768
3 773 768 279
3 279 280 773
3 774 773 280
3 280 285 774
3 779 774 285
3 285 289 779
3 783 779 289
3 289 293 783
3 293 787 783
3 293 299 787
3 793 787 299
3 299 304 793
3 304 798 793
3 304 309 798
3 803 798 309
3 309 310 803
3 804 803 310
3 310 316 804
3 810 804 316
3 316 322 810
3 816 810 322
3 322 327 816
3 821 816 327
3 327 332 821
3 332 826 821
3 332 338 826
3 832 826 338
3 338 339 832
3 833 832 339
3 339 344 833
3 838 833 344
3 344 349 838
3 843 838 349
3 349 350 843
3 844 843 350
3 350 356 844
3 356 850 844
3 356 357 850
3 851 850 357
3 357 358 851
3 852 851 358
3 358 359 852
3 853 852 359
3 359 367 853
3 861 853 367
3 367 368 861
3 862 861 368
3 368 369 862
3 863 862 369
3 369 379 863
3 873 863 379
3 379 380 873
3 874 873 380
3 380 381 874
3 875 874 381
3 381 382 875
3 876 875 382
3 382 392 876
3 392 886 876
3 392 393 886
3 887 886 393
3 393 394 887
3 887 394 888
3 394 395 888
3 889 888 395
3 395 396 889
3 890 889 396
3 396 397 890
3 891 890 397
3 397 398 891
3 892 891 398
3 398 407 892
3 901 892 407
3 407 408 901
3 408 902 901
3 408 409 902
3 903 902 409
3 409 410 903
3 903 410 904
3 410 411 904
3 905 904 411
3 411 412 905
3 412 906 905
3 412 421 906
3 915 906 421
3 421 422 915
3 916 915 422
3 422 413 916
3 907 916 413
3 413 414 907
3 908 907 414
3 414 415 908
3 909 908 415
3 415 416 909
3 910 909 416
3 416 399 910
3 893 910 399
3 399 400 893
3 894 893 400
3 400 401 894
3 895 894 401
3 401 402 895
3 896 895 402
3 402 383 896
3 877 896 383
3 383 384 877
3 878 877 384
3 384 385 878
3 879 878 385
3 385 386 879
3 880 879 386
3 386 387 880
3 881 880 387
3 387 370 881
3 864 881 370
3 370 371 864
3 865 864 371
3 371 372 865
3 866 865 372
3 372 373 866
3 867 866 373
3 373 374 867
3 868 867 374
3 374 360 868
3 854 868 360
3 360 361 854
3 855 854 361
3 361 362 855
3 362 856 855
3 362 351 856
3 351 845 856
3 351 345 845
3 839 845 345
3 345 346 839
3 840 839 346
3 346 340 840
3 834 840 340
3 340 333 834
3 827 834 333
3 333 334 827
3 828 827 334
3 334 328 828
3 328 822 828
3 328 323 822
3 817 822 323
3 323 324 817
3 818 817 324
3 324 317 818
3 811 818 317
3 317 318 811
3 318 812 811
3 318 311 812
3 805 812 311
3 311 312 805
3 806 805 312
3 312 305 806
3 799 806 305
3 305 306 799
3 800 799 306
3 306 300 800
3 794 800 300
3 300 301 794
3 795 794 301
3 301 294 795
3 788 795 294
3 294 295 788
3 789 788 295
3 295 290 789
3 784 789 290
3 290 286 784
3 780 784 286
3 286 281 780
3 775 780 281
3 281 275 775
3 769 775 275
3 275 276 769
3 770 769 276
3 276 271 770
3 271 765 770
3 271 267 765
3 761 765 267
3 267 260 761
3 260 754 761
3 260 255 754
3 749 754 255
3 255 250 749
3 250 744 749
3 250 249 744
3 743 744 249
3 249 243 743
3 737 743 243
3 243 244 737
3 738 737 244
3 244 239 738
3 733 738 239
3 239 233 733
3 727 733 233
3 233 229 727
3 723 727 229
3 229 224 723
3 224 718 723
3 224 218 718
3 712 718 218
3 218 214 712
3 708 712 214
3 214 209 708
3 703 708 209
3 209 205 703
3 205 699 703
3 205 199 699
3 199 693 699
3 199 198 693
3 692 693 198
3 198 193 692
3 687 692 193
3 193 188 687
3 682 687 188
3 188 187 682
3 681 682 187
3 187 183 681
3 677 681 183
3 183 182 677
3 676 677 182
3 182 175 676
3 175 669 676
3 175 174 669
3 668 669 174
3 174 167 668
3 661 668 167
3 167 166 661
3 660 661 166
3 166 165 660
3 659 660 165
3 165 160 659
3 654 659 160
3 160 159 654
3 653 654 159
3 159 158 653
3 652 653 158
3 158 152 652
3 652 152 646
3 152 151 646
3 645 646 151
3 151 145 645
3 145 639 645
3 145 144 639
3 144 638 639
3 144 143 638
3 637 638 143
3 143 142 637
3 636 637 142
3 142 135 636
3 629 636 135
3 135 134 629
3 628 629 134
3 134 133 628
3 627 628 133
3 133 127 627
3 621 627 127
3 127 119 621
3 613 621 119
3 119 118 613
3 612 613 118
3 118 117 612
3 611 612 117
3 117 111 611
3 605 611 111
3 111 110 605
3 110 604 605
3 110 101 604
3 595 604 101
3 101 100 595
3 594 595 100
3 100 93 594
3 587 594 93
3 93 92 587
3 586 587 92
3 92 91 586
3 585 586 91
3 91 83 585
3 83 577 585
3 83 82 577
3 82 576 577
3 82 81 576
3 81 575 576
3 81 80 575
3 574 575 80
3 80 79 574
3 573 574 79
3 79 77 573
3 571 573 77
3 77 78 571
3 572 571 78
3 78 90 572
3 90 584 572
3 90 76 584
3 570 584 76
3 76 74 570
3 568 570 74
3 245 249 251
3 739 743 745
3 251 249 250
3 745 743 744
3 251 250 256
3 745 744 750
3 256 250 255
3 750 744 749
3 256 255 261
3 750 749 755
3 261 255 268
3 755 749 762
3 268 255 260
3 762 749 754
3 268 260 272
3 762 754 766
3 272 260 267
3 766 754 761
3 272 267 277
3 766 761 771
3 277 267 271
3 771 761 765
3 277 271 282
3 771 765 776
3 282 271 283
3 776 765 777
3 283 271 276
3 777 765 770
3 283 276 287
3 777 770 781
3 287 276 275
3 781 770 769
3 287 275 291
3 781 769 785
3 291 275 296
3 785 769 790
3 296 275 281
3 790 769 775
3 296 281 297
3 790 775 791
3 297 281 286
3 791 775 780
3 297 286 302
3 791 780 796
3 302 286 307
3 796 780 801
3 307 286 290
3 801 780 784
3 307 290 313
3 801 784 807
3 313 290 295
3 807 784 789
3 313 295 319
3 807 789 813
3 319 295 320
3 813 789 814
3 320 295 294
3 814 789 788
3 320 294 325
3 814 788 819
3 325 294 301
3 819 788 795
3 325 301 329
3 819 795 823
3 329 301 300
3 823 795 794
3 329 300 330
3 823 794 824
3 330 300 335
3 824 794 829
3 335 300 306
3 829 794 800
3 335 306 336
3 829 800 830
3 336 306 305
3 830 800 799
3 336 305 341
3 830 799 835
3 341 305 342
3 835 799 836
3 342 305 312
3 836 799 806
3 342 312 347
3 836 806 841
3 347 312 311
3 841 806 805
3 347 311 352
3 841 805 846
3 352 311 318
3 846 805 812
3 352 318 353
3 846 812 847
3 353 318 363
3 847 812 857
3 363 318 317
3 857 812 811
3 363 317 364
3 857 811 858
3 364 317 324
3 858 811 818
3 364 324 375
3 858 818 869
3 375 324 376
3 869 818 870
3 376 324 323
3 870 818 817
3 376 323 388
3 870 817 882
3 388 323 328
3 882 817 822
3 388 328 403
3 882 822 897
3 403 328 404
3 897 822 898
3 404 328 334
3 898 822 828
3 404 334 417
3 898 828 911
3 417 334 333
3 911 828 827
3 417 333 418
3 911 827 912
3 418 333 423
3 912 827 917
3 423 333 340
3 917 827 834
3 423 340 424
3 917 834 918
3 424 340 346
3 918 834 840
3 424 346 428
3 918 840 922
3 428 346 429
3 922 840 923
3 429 346 345
3 923 840 839
3 429 345 432
3 923 839 926
3 432 345 351
3 926 839 845
3 432 351 433
3 926 845 927
3 433 351 362
3 927 845 856
3 433 362 436
3 927 856 930
3 436 362 437
3 930 856 931
3 437 362 361
3 931 856 855
3 437 361 443
3 931 855 937
3 443 361 360
3 937 855 854
3 443 360 441
3 937 854 935
3 441 360 442
3 935 854 936
3 442 360 374
3 936 854 868
3 442 374 450
3 936 868 944
3 450 374 373
3 944 868 867
3 450 373 449
3 944 867 943
3 449 373 447
3 943 867 941
3 447 373 372
3 941 867 866
3 447 372 448
3 941 866 942
3 448 372 371
3 942 866 865
3 448 371 455
3 942 865 949
3 455 371 453
3 949 865 947
3 453 371 370
3 947 865 864
3 453 370 454
3 947 864 948
3 454 370 387
3 948 864 881
3 454 387 459
3 948 881 953
3 459 387 460
3 953 881 954
3 460 387 386
3 954 881 880
3 460 386 468
3 954 880 962
3 468 386 467
3 962 880 961
3 467 386 385
3 961 880 879
3 467 385 466
3 961 879 960
3 466 385 384
3 960 879 878
3 466 384 464
3 960 878 958
3 464 384 465
3 958 878 959
3 465 384 383
3 959 878 877
3 465 383 476
3 959 877 970
3 476 383 402
3 970 877 896
3 476 402 475
3 970 896 969
3 475 402 474
3 969 896 968
3 474 402 401
3 968 896 895
3 474 401 472
3 968 895 966
3 472 401 400
3 966 895 894
3 472 400 473
3 966 894 967
3 473 400 399
3 967 894 893
3 473 399 485
3 967 893 979
3 485 399 484
3 979 893 978
3 484 399 416
3 978 893 910
3 484 416 483
3 978 910 977
3 483 416 415
3 977 910 909
3 483 415 481
3 977 909 975
3 481 415 414
3 975 909 908
3 481 414 482
3 975 908 976
3 482 414 493
3 976 908 987
3 493 414 413
3 987 908 907
3 493 413 492
3 987 907 986
3 492 413 422
3 986 907 916
3 492 422 491
3 986 916 985
3 491 422 421
3 985 916 915
3 491 421 490
3 985 915 984
3 490 421 412
3 984 915 906
3 490 412 489
3 984 906 983
3 489 412 411
3 983 906 905
3 489 411 488
3 983 905 982
3 488 411 487
3 982 905 981
3 487 411 410
3 981 905 904
3 487 410 486
3 981 904 980
3 486 410 409
3 980 904 903
3 486 409 480
3 980 903 974
3 480 409 479
3 974 903 973
3 479 409 408
3 973 903 902
3 479 408 478
3 973 902 972
3 478 408 407
3 972 902 901
3 478 407 477
3 972 901 971
3 477 407 471
3 971 901 965
3 471 407 398
3 965 901 892
3 471 398 470
3 965 892 964
3 470 398 469
3 964 892 963
3 469 398 397
3 963 892 891
3 469 397 463
3 963 891 957
3 463 397 396
3 957 891 890
3 463 396 462
3 957 890 956
3 462 396 461
3 956 890 955
3 461 396 395
3 955 890 889
3 461 395 458
3 955 889 952
3 458 395 457
3 952 889 951
3 457 395 394
3 951 889 888
3 457 394 456
3 951 888 950
3 456 394 393
3 950 888 887
3 456 393 452
3 950 887 946
3 452 393 451
3 946 887 945
3 451 393 392
3 945 887 886
3 451 392 446
3 945 886 940
3 446 392 382
3 940 886 876
3 446 382 445
3 940 876 939
3 445 382 444
3 939 876 938
3 444 382 381
3 938 876 875
3 444 381 440
3 938 875 934
3 440 381 380
3 934 875 874
3 440 380 439
3 934 874 933
3 439 380 379
3 933 874 873
3 439 379 438
3 933 873 932
3 438 379 435
3 932 873 929
3 435 379 369
3 929 873 863
3 435 369 434
3 929 863 928
3 434 369 368
3 928 863 862
3 434 368 431
3 928 862 925
3 431 368 367
3 925 862 861
3 431 367 430
3 925 861 924
3 430 367 427
3 924 861 921
3 427 367 359
3 921 861 853
3 427 359 426
3 921 853 920
3 426 359 358
3 920 853 852
3 426 358 425
3 920 852 919
3 425 358 357
3 919 852 851
3 425 357 420
3 919 851 914
3 420 357 419
3 914 851 913
3 419 357 356
3 913 851 850
3 419 356 406
3 913 850 900
3 406 356 350
3 900 850 844
3 406 350 405
3 900 844 899
3 405 350 349
3 899 844 843
3 405 349 391
3 899 843 885
3 391 349 344
3 885 843 838
3 391 344 390
3 885 838 884
3 390 344 389
3 884 838 883
3 389 344 339
3 883 838 833
3 389 339 378
3 883 833 872
3 378 339 338
3 872 833 832
3 378 338 377
3 872 832 871
3 377 338 366
3 871 832 860
3 366 338 332
3 860 832 826
3 366 332 365
3 860 826 859
3 365 332 327
3 859 826 821
3 365 327 355
3 859 821 849
3 355 327 354
3 849 821 848
3 354 327 322
3 848 821 816
3 354 322 348
3 848 816 842
3 348 322 316
3 842 816 810
3 348 316 343
3 842 810 837
3 343 316 310
3 837 810 804
3 343 310 337
3 837 804 831
3 337 310 331
3 831 804 825
3 331 310 309
3 825 804 803
3 331 309 326
3 825 803 820
3 326 309 304
3 820 803 798
3 326 304 321
3 820 798 815
3 321 304 299
3 815 798 793
3 321 299 315
3 815 793 809
3 315 299 314
3 809 793 808
3 314 299 293
3 808 793 787
3 314 293 308
3 808 787 802
3 308 293 289
3 802 787 783
3 308 289 303
3 802 783 797
3 303 289 298
3 797 783 792
3 298 289 285
3 792 783 779
3 298 285 292
3 792 779 786
3 292 285 280
3 786 779 774
3 292 280 288
3 786 774 782
3 288 280 279
3 782 774 773
3 288 279 284
3 782 773 778
3 284 279 274
3 778 773 768
3 284 274 278
3 778 768 772
3 278 274 270
3 772 768 764
3 278 270 273
3 772 764 767
3 273 270 266
3 767 764 760
3 273 266 269
3 767 760 763
3 269 266 265
3 763 760 759
3 269 265 264
3 763 759 758
3 264 265 259
3 758 759 753
3 264 259 263
3 758 753 757
3 263 259 258
3 757 753 752
3 263 258 262
3 757 752 756
3 262 258 257
3 756 752 751
3 257 258 254
3 751 752 748
3 257 254 253
3 751 748 747
3 253 254 248
3 747 748 742
3 253 248 252
3 747 742 746
3 252 248 246
3 746 742 740
3 246 248 247
3 740 742 741
3 246 247 241
3 740 741 735
3 241 247 242
3 735 741 736
3 241 242 235
3 735 736 729
3 235 242 236
3 729 736 730
3 236 242 238
3 730 736 732
3 236 238 231
3 730 732 725
3 231 238 237
3 725 732 731
3 231 237 226
3 725 731 720
3 226 237 227
3 720 731 721
3 227 237 232
3 721 731 726
3 227 232 221
3 721 726 715
3 221 232 228
3 715 726 722
3 221 228 216
3 715 722 710
3 216 228 223
3 710 722 717
3 216 223 211
3 710 717 705
3 211 223 222
3 705 717 716
3 211 222 207
3 705 716 701
3 207 222 202
3 701 716 696
3 202 222 217
3 696 716 711
3 202 217 195
3 696 711 689
3 195 217 213
3 689 711 707
3 195 213 196
3 689 707 690
3 196 213 190
3 690 707 684
3 190 213 212
3 684 707 706
3 190 212 185
3 684 706 679
3 185 212 208
3 679 706 702
3 185 208 177
3 679 702 671
3 177 208 178
3 671 702 672
3 178 208 204
3 672 702 698
3 178 204 179
3 672 698 673
3 179 204 170
3 673 698 664
3 170 204 203
3 664 698 697
3 170 203 171
3 664 697 665
3 171 203 197
3 665 697 691
3 171 197 162
3 665 691 656
3 162 197 155
3 656 691 649
3 155 197 192
3 649 691 686
3 155 192 147
3 649 686 641
3 147 192 191
3 641 686 685
3 147 191 138
3 641 685 632
3 138 191 186
3 632 685 680
3 138 186 139
3 632 680 633
3 139 186 130
3 633 680 624
3 130 186 181
3 624 680 675
3 130 181 122
3 624 675 616
3 122 181 180
3 616 675 674
3 122 180 123
3 616 674 617
3 123 180 114
3 617 674 608
3 114 180 173
3 608 674 667
3 114 173 104
3 608 667 598
3 104 173 172
3 598 667 666
3 104 172 105
3 598 666 599
3 105 172 96
3 599 666 590
3 96 172 164
3 590 666 658
3 96 164 86
3 590 658 580
3 86 164 87
3 580 658 581
3 87 164 163
3 581 658 657
3 87 163 72
3 581 657 566
3 72 163 157
3 566 657 651
3 72 157 73
3 566 651 567
3 73 157 68
3 567 651 562
3 68 157 156
3 562 651 650
3 68 156 69
3 562 650 563
3 69 156 149
3 563 650 643
3 69 149 65
3 563 643 559
3 65 149 66
3 559 643 560
3 66 149 148
3 560 643 642
3 66 148 60
3 560 642 554
3 60 148 61
3 554 642 555
3 61 148 150
3 555 642 644
3 61 150 56
3 555 644 550
3 56 150 141
3 550 644 635
3 56 141 57
3 550 635 551
3 57 141 51
3 551 635 545
3 51 141 140
3 545 635 634
3 51 140 52
3 545 634 546
3 52 140 132
3 546 634 626
3 52 132 53
3 546 626 547
3 53 132 45
3 547 626 539
3 45 132 131
3 539 626 625
3 45 131 46
3 539 625 540
3 46 131 47
3 540 625 541
3 47 131 125
3 541 625 619
3 47 125 39
3 541 619 533
3 39 125 124
3 533 619 618
3 39 124 40
3 533 618 534
3 40 124 41
3 534 618 535
3 41 124 126
3 535 618 620
3 41 126 35
3 535 620 529
3 35 126 116
3 529 620 610
3 35 116 36
3 529 610 530
3 36 116 25
3 530 610 519
3 25 116 115
3 519 610 609
3 25 115 26
3 519 609 520
3 26 115 107
3 520 609 601
3 26 107 27
3 520 601 521
3 27 107 28
3 521 601 522
3 28 107 106
3 522 601 600
3 28 106 29
3 522 600 523
3 29 106 108
3 523 600 602
3 29 108 30
3 523 602 524
3 30 108 109
3 524 602 603
3 30 109 31
3 524 603 525
3 31 109 32
3 525 603 526
3 32 109 98
3 526 603 592
3 32 98 20
3 526 592 514
3 20 98 97
3 514 592 591
3 20 97 21
3 514 591 515
3 21 97 0
3 515 591 494
3 0 97 99
3 494 591 593
3 0 99 1
3 494 593 495
3 1 99 89
3 495 593 583
3 1 89 2
3 495 583 496
3 2 89 88
3 496 583 582
3 2 88 3
3 496 582 497
3 3 88 75
3 497 582 569
3 3 75 4
3 497 569 498
3 4 75 74
3 498 569 568
3 4 74 5
3 498 568 499
3 5 74 76
3 499 568 570
3 5 76 90
3 499 570 584
3 5 90 6
3 499 584 500
3 6 90 78
3 500 584 572
3 6 78 7
3 500 572 501
3 7 78 77
3 501 572 571
3 7 77 8
3 501 571 502
3 8 77 79
3 502 571 573
3 8 79 9
3 502 573 503
3 9 79 10
3 503 573 504
3 10 79 80
3 504 573 574
3 10 80 11
3 504 574 505
3 11 80 81
3 505 574 575
3 11 81 12
3 505 575 506
3 12 81 82
3 506 575 576
3 12 82 13
3 506 576 507
3 13 82 83
3 507 576 577
3 13 83 14
3 507 577 508
3 14 83 91
3 508 577 585
3 14 91 15
3 508 585 509
3 15 91 92
3 509 585 586
3 15 92 16
3 509 586 510
3 16 92 17
3 510 586 511
3 17 92 93
3 511 586 587
3 17 93 18
3 511 587 512
3 18 93 100
3 512 587 594
3 18 100 19
3 512 594 513
3 19 100 101
3 513 594 595
3 19 101 22
3 513 595 516
3 22 101 23
3 516 595 517
3 23 101 110
3 517 595 604
3 23 110 24
3 517 604 518
3 24 110 111
3 518 604 605
3 24 111 33
3 518 605 527
3 33 111 34
3 527 605 528
3 34 111 117
3 528 605 611
3 34 117 37
3 528 611 531
3 37 117 118
3 531 611 612
3 37 118 38
3 531 612 532
3 38 118 42
3 532 612 536
3 42 118 119
3 536 612 613
3 42 119 43
3 536 613 537
3 43 119 127
3 537 613 621
3 43 127 44
3 537 621 538
3 44 127 48
3 538 621 542
3 48 127 133
3 542 621 627
3 48 133 49
3 542 627 543
3 49 133 50
3 543 627 544
3 50 133 134
3 544 627 628
3 50 134 54
3 544 628 548
3 54 134 135
3 548 628 629
3 54 135 55
3 548 629 549
3 55 135 58
3 549 629 552
3 58 135 142
3 552 629 636
3 58 142 59
3 552 636 553
3 59 142 143
3 553 636 637
3 59 143 62
3 553 637 556
3 62 143 63
3 556 637 557
3 63 143 144
3 557 637 638
3 63 144 64
3 557 638 558
3 64 144 67
3 558 638 561
3 67 144 145
3 561 638 639
3 67 145 70
3 561 639 564
3 70 145 151
3 564 639 645
3 70 151 71
3 564 645 565
3 71 151 84
3 565 645 578
3 84 151 152
3 578 645 646
3 84 152 85
3 578 646 579
3 85 152 158
3 579 646 652
3 85 158 94
3 579 652 588
3 94 158 95
3 588 652 589
3 95 158 159
3 589 652 653
3 95 159 102
3 589 653 596
3 102 159 160
3 596 653 654
3 102 160 103
3 596 654 597
3 103 160 165
3 597 654 659
3 103 165 112
3 597 659 606
3 112 165 113
3 606 659 607
3 113 165 166
3 607 659 660
3 113 166 120
3 607 660 614
3 120 166 167
3 614 660 661
3 120 167 121
3 614 661 615
3 121 167 128
3 615 661 622
3 128 167 174
3 622 661 668
3 128 174 129
3 622 668 623
3 129 174 175
3 623 668 669
3 129 175 136
3 623 669 630
3 136 175 182
3 630 669 676
3 136 182 137
3 630 676 631
3 137 182 146
3 631 676 640
3 146 182 183
3 640 676 677
3 146 183 153
3 640 677 647
3 153 183 187
3 647 677 681
3 153 187 154
3 647 681 648
3 154 187 188
3 648 681 682
3 154 188 161
3 648 682 655
3 161 188 168
3 655 682 662
3 168 188 193
3 662 682 687
3 168 193 169
3 662 687 663
3 169 193 198
3 663 687 692
3 169 198 176
3 663 692 670
3 176 198 199
3 670 692 693
3 176 199 184
3 670 693 678
3 184 199 189
3 678 693 683
3 189 199 205
3 683 693 699
3 189 205 194
3 683 699 688
3 194 205 209
3 688 699 703
3 194 209 200
3 688 703 694
3 200 209 201
3 694 703 695
3 201 209 214
3 695 703 708
3 201 214 206
3 695 708 700
3 206 214 218
3 700 708 712
3 206 218 210
3 700 712 704
3 210 218 215
3 704 712 709
3 215 218 224
3 709 712 718
3 215 224 219
3 709 718 713
3 219 224 220
3 713 718 714
3 220 224 229
3 714 718 723
3 220 229 225
3 714 723 719
3 225 229 233
3 719 723 727
3 225 233 230
3 719 727 724
3 230 233 239
3 724 727 733
3 230 239 234
3 724 733 728
3 234 239 244
3 728 733 738
3 234 244 240
3 728 738 734
3 240 244 243
3 734 738 737
3 240 243 245
3 734 737 739
3 245 243 249
3 739 737 743
