cgal-discuss - Re: [cgal-discuss] Intersection of a ray and a delaunay triangulation
  • To:
  • Subject: Re: [cgal-discuss] Intersection of a ray and a delaunay triangulation
  • Date: Thu, 24 Mar 2016 17:11:52 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:LAUIZBMECzzcb5aQPhYl6mtUPXoX/o7sNwtQ0KIMzox0Kfz/rarrMEGX3/hxlliBBdydsKIUzbOG+PC4EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35TxjrD5q8WbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/NGSrjwKqQkUaRDXnNhKHEw/MSttB/ZTALJ6GFbSXQTihMPAg7L61bxUZ719yf7reFgwzLJAcqjRr89XXGu7rxgVQTzoCYBLT8wtm/N2eJqi6cOmBWlkDl4xZVPV7mILub7SYPQedIfTHIJCt5WU2pEBYWnaKMPAu4AOO9A6YL98Qhd5SCiDBWhUbu8ggRDgWX7iPU3
Thanks Andreas, I'm fiddling with it now.
Considering the tree. What would be the memory impact of having the tree?
Will it provoke a duplication of the point data?
Aside question, is it possible to have a triangle face circulator? As the line face circulator, a method that retrieves all cdt's faces intersected by a triangle.
Cheers,
Pol
On Thu, Mar 24, 2016 at 2:23 PM, Andreas Fabri <> wrote:
On 24/03/2016 13:19, Olivier Devillers wrote:
On 24 Mar 2016, at 12:33, Pol Monsó Purtí Helimap <
<mailto:>> wrote:
Hello all,
How can I intersect a 3d ray with a 2D Constrained Delaunay
Triangulation created from 3d points using the project_xy traits?
I've seen this post:
http://cgal-discuss.949826.n4.nabble.com/Intersection-segment-and-cells-from-3D-Delaunay-triangulation-td4660891.html
But I don't understand andreas for the second approach.
I don't have that many queries, around 200 of them. I might have,
however, lots of points, > 200 milion.
Is it worth it to build a tree? what other approach could I follow?
Iterating over all the faces seems highly inefficient.
for one ray, you could iterate on the faces intersecting the ray in
projection using the line-face-circulator.
Look for
Line Face Circulator
http://doc.cgal.org/4.8/Triangulation_2/classCGAL_1_1Triangulation__2.html#ad720b1a9adc835ed1a27c228eea1e36c
It might still be a rather expensive operation, namely when
you only intersect very few triangles close to mountain peaks,
but traverse all the triangles in the vertical projection
(~sqrt(200 mio)).
Give the AABB tree a try. It will take you an hour to implement.
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912    skype: andreas.fabri
