- To:
- Subject: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs
- Date: Wed, 30 Mar 2016 15:16:20 +0200
Hi,
From the documentation, the Minkoswki package can compute exact or approximate
offset and inset of polygons, resulting in a General_polygon_set_2 made of
line
segments and circle arcs.
And General_polygon_set_2 can be manipulated via boolean operations.
There seem to be a missing element : the ability to inset or offset a
General_polygon_set_2 which already comprises some circle arcs (instead of
being made of 100% pure line segments).
It seems to me (naively) that this should be possible since the offset or
inset of a piece of boundary which is a circular arc is itself a circular
arc, so that the offset or inset of a
General_polygon_set_2<Gps_circle_segment_traits_2>
should be, as well, a General_polygon_set_2<Gps_circle_segment_traits_2>
To sum up, can I do this with CGAL?
typedef General_polygon_set_2<Gps_circle_segment_traits_2> CoolShape;
CoolShape A, B, C;
C = approximate_inset(B, 300, 1.0).intersection( C );
(I believe that it’s not possible since, currently, B is expected to be
purely linear.)
Thank you in advance,
Samuel
- [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs, Samuel Hornus, 03/30/2016
- Re: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs, Efi Fogel, 03/31/2016
- Re: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs, Monique Teillaud, 03/31/2016
- Re: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs, Pratyush Pranav, 03/31/2016
