Re: [cgal-discuss] question on CGAL::create_exterior_skeleton_and_offset_polygons_2
- To:
- Subject: Re: [cgal-discuss] question on CGAL::create_exterior_skeleton_and_offset_polygons_2
- Date: Sat, 16 Apr 2016 18:53:40 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:sno9zhWDO7hIPlsbDUzfzg09CYnV8LGtZVwlr6E/grcLSJyIuqrYZh2Dt8tkgFKBZ4jH8fUM07OQ6PCwHzFRqsne+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq82VPlQD22X1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5k+VqFSWTQ6L3gutoqsrgjGVQLJ530GU2xQnAAPGBnA9Bi9X5H/tWzxueN5nSWbJsbrVqtnZTP35KhiTFrkiTwMKiUi2GDRkM15yqxB8zy7oBkq44ndZo7dG/t3eKyVV84bDT5BUcxSDXQZUquzaoIOC6wKOuMO/Nq1nEcHsRbrXVrkP+jo0DId3nI=
Thanks for the clarification
Giang
> On 15 Apr 2016, at 10:19, Sebastien Loriot (GeometryFactory)
> wrote:
> IIRC, in order to compute the offset, a large bbox is put around the input
> model. The extra output polygon is the offset of the bbox.
> Sebastien.
>> On 04/15/2016 09:46 AM, Hoang Giang Bui wrote:
>> Hello
>> I have a simple question. To create an offset polygon I used the code
>> from examples:
>> Polygon_2 poly ;
>> poly.push_back( Point(0,0) ) ;
>> poly.push_back( Point(1,0) ) ;
>> poly.push_back( Point(1,1) ) ;
>> poly.push_back( Point(0,1) ) ;
>> FT lOffset = 0.1 ;
>> PolygonPtrVector outer_offset_polygons =
>> CGAL::create_exterior_skeleton_and_offset_polygons_2(lOffset,poly);
>> print_polygons(outer_offset_polygons);
>> But it produces two polygons:
>> Polygon list with 2 polygons
>> Polygon with 4 vertices
>> (-0.146421,-0.146421)
>> (1.14642,-0.146421)
>> (1.14642,1.14642)
>> (-0.146421,1.14642)
>> (-0.1,1.1)
>> (1.1,1.1)
>> (1.1,-0.1)
>> (-0.1,-0.1)
>> The second is correct but the first seems hard to understand. Does
>> anyone have idea what it is?
>> Giang
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] question on CGAL::create_exterior_skeleton_and_offset_polygons_2, Hoang Giang Bui, 04/15/2016
- Re: [cgal-discuss] question on CGAL::create_exterior_skeleton_and_offset_polygons_2, Sebastien Loriot (GeometryFactory), 04/15/2016
- Re: [cgal-discuss] question on CGAL::create_exterior_skeleton_and_offset_polygons_2, Hoang Giang Bui, 04/16/2016
