- To:
- Subject: Re: [cgal-discuss] Failing to run CGAL
- Date: Mon, 18 Apr 2016 08:54:47 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:5QnpLhUNT5RqWgTQ2XW0GUQ859HV8LGtZVwlr6E/grcLSJyIuqrYZhKBt8tkgFKBZ4jH8fUM07OQ6PCwHzJZqs/Y6zgrS99laVwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oM2DJVsRz2PkOvtbF1afk0b4joEum4xsK6I8mFPig0BjXKBo/15uPk+ZhB3m5829r9ZJ+iVUvO89pYYbCf2pN/dwcbsNBzsvNyU55dbgqALYZQqJ/HoVFGsMwTRSBA2Qpir3VJ7qrir3sKJZ3zObOtG+DZ85XjGv8716ZhbjlCAdJn9zuDXMjstqjaVH5heljxN6yo/QJoqSMawtLevmYdoGSD8ZDY5qXCtbD9bkYg==
On 04/15/2016 10:14 PM, Ignas Brašiškis wrote:
I cannot compile CGAL using application, because it Can't findPlease provide some context and a minimal example showing the problem.
definition. Do you have any idea what could be wrong
/usr/include/CGAL/Constrained_Delaunay_triangulation_face_base_2.h:42:
error: no type named 'Point_2' in 'class
CGAL::Triangulation_vertex_base_2<CGAL::Epick>'
typedef typename Kernel::Point_2 Point;
Otherwise it is hard to help.
Sebastien.
- [cgal-discuss] Failing to run CGAL, Ignas Brašiškis, 04/15/2016
- Re: [cgal-discuss] Failing to run CGAL, Sebastien Loriot (GeometryFactory), 04/18/2016
- Re: [cgal-discuss] Failing to run CGAL, Ignas Brašiškis, 04/19/2016
- Re: [cgal-discuss] Failing to run CGAL, Sebastien Loriot (GeometryFactory), 04/19/2016
