- To:
- Subject: Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d
- Date: Mon, 25 Apr 2016 11:58:46 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:qE1SABJPsCPLIbRqQNmcpTZWNBhigK39O0sv0rFitYgUI/rxwZ3uMQTl6Ol3ixeRBMOAu6IC1LSd4vmocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC34LoiavjotX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86FpyshbTK+vf7gkVacKS3M9ImUt7YvqswPCRE2B/DwHQ2AOm11JBQbCqxr1V5O0virhvfdmw3qmOpj9QrkwHDij9Kx2UwTAiSEdNjd//nuEpNZ3ifd1upOtJgZ+wMbsaZucOPtlNvfTZdoATDIcDu5MUDBdC5y1KYAGWblSdd1EppXw8gNd5SC1AhOhUbvi
For the specialization you can use the nested Kernel_tag for the Kernel
you are using that is either CGAL::Homogeneous_tag or
CGAL::Cartesian_tag.
Also, for that part, I did not succeed to make a specialization using the Kernel_tag. All my tests had compiled errors and also the fact that partial specialization of a method is not allowed. Do you have any example of that? Another thing is that the Kernel_tag does not seem to be a documented feature and the Homogeneous_d kernel does not provide it, although it provides Rep_tag which I don't know what it is.
Thank you.
Frédérik
2016-04-20 8:38 GMT-04:00 Frédérik Paradis <>:
FrédérikHi Marc,As you may have heard, I'm currently developing a package intended to be included in CGAL so I want that my package be able to support almost every type of points. And for Homogeneous_d<int>, it was just a test.2016-04-20 8:23 GMT-04:00 Marc Glisse <>:Hello,
out of curiosity, why are you using Homogeneous_d, and in particular Homogeneous_d<double>? Homogeneous_d<int> also sounds rather dangerous.
Marc Glisse
- [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Frédérik Paradis, 04/16/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Sebastien Loriot (GeometryFactory), 04/18/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Frédérik Paradis, 04/18/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Sebastien Loriot (GeometryFactory), 04/19/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Frédérik Paradis, 04/19/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Sebastien Loriot (GeometryFactory), 04/20/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Frédérik Paradis, 04/20/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Marc Glisse, 04/20/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Frédérik Paradis, 04/25/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Sebastien Loriot (GeometryFactory), 04/26/2016
