- To:
- Subject: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d
- Date: Fri, 15 Apr 2016 18:28:18 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:Km1czRyV8QW81T3XCy+O+j09IxM/srCxBDY+r6Qd0e4VIJqq85mqBkHD//Il1AaPBtWLra8UwLOK+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuSt6U0pT8jrz60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVPWKG/c6UjRqFDFxwnNXo07Yvlr0rtVwyKs1UG02mXiBtLSzDM9hj2X4y55iXiv/B0gHTKFdDxUaw9Rj3k5K49G0ygszsOKzNsqDKfscd3lq8O+B8=
HI,
I am using the class Point_containter to generate and split the bounding box of a point set. I would like to get the bounding box as an Iso_box_d. However, the Point_container class only offers a method bounding_box which return a Kd_tree_rectangle. The only way to retrieve the coordinates of the corners of the rectangle seems to be the methods min_coord and max_coord which both returns the cartesian coordinate for the dimension i with the type FT.The problem arises when I'm using the Homogeneous_d kernel with whatever ring type because the ring type and the field type are not the same and thus trigger a compilation error.
std::vector<FT> min;
std::vector<FT> max;
const Kd_tree_rectangle<FT, D>& kdbox = container.bounding_box();
for(int i = 0; i < d; i++) {
min.push_back(kdbox.min_coord(i));
max.push_back(kdbox.max_coord(i));
bbox = Iso_box_d(Point_d(d, min.begin(), min.end()),
Point_d(d, max.begin(), max.end()));
- [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Frédérik Paradis, 04/16/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Sebastien Loriot (GeometryFactory), 04/18/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Frédérik Paradis, 04/18/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Sebastien Loriot (GeometryFactory), 04/19/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Frédérik Paradis, 04/19/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Sebastien Loriot (GeometryFactory), 04/20/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Frédérik Paradis, 04/20/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Marc Glisse, 04/20/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Frédérik Paradis, 04/25/2016
- Re: [cgal-discuss] Get corners of a Kd_tree_rectangle as Point_d, Sebastien Loriot (GeometryFactory), 04/26/2016
