- To:
- Subject: [cgal-discuss] Method for populating container with finite_vertices?
- Date: Thu, 28 Apr 2016 12:26:36 -0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:WnpbfhLIHzfmVtdsUtmcpTZWNBhigK39O0sv0rFitYgULvrxwZ3uMQTl6Ol3ixeRBMOAu6IC27ad6vu8EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35Txh7z5osaPKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxcK08CLBZFz87KHsd5cvxtBCFQxHcyGEbVzA/nhNNSyfI8Br6U5P1+n/zuuN4niaXIcb2QLQwcTun5qZvDhTvjXFUZHYC7GjLh5ko3+pgqxW7qkknzg==
Hi all,
Just in case I missed it in the documentation, is there a method which pushes all finite_vertices into a std::vector<Vertex_handle>?
(I know it’s trivial to write with the Finite_vertex_iterator, checking to see if I even need that.)
- [cgal-discuss] Method for populating container with finite_vertices?, Adam Getchell, 04/28/2016
- Re: [cgal-discuss] Method for populating container with finite_vertices?, Andreas Fabri, 04/28/2016
- Re: [cgal-discuss] Method for populating container with finite_vertices?, Sebastien Loriot (GeometryFactory), 04/28/2016
- Re: [cgal-discuss] Method for populating container with finite_vertices?, Adam Getchell, 04/28/2016
