- To:
- Subject: Re: [cgal-discuss] Method for populating container with finite_vertices?
- Date: Thu, 28 Apr 2016 13:41:06 -0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:NikcdBZGZ5YZFidarYFKFpL/LSx+4OfEezUN459isYplN5qZpcWzbnLW6fgltlLVR4KTs6sC0LqG9fC8EjVcv96oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDivc2PKFwU2nKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQqIjULYNDCg6K3tno4rwpBzbRE2O4GEdWyMYiF1TEg3d5Vb7WJn29SD1v+441CiBNtDtVuMIXmGp4K5vDRPpkywaLCUR8WfNi8U2grgIjgimoklWz4fRKK6YKPF+c6fZNYcTSWNEGMlcSydBD4e4R4QKBusFe+1fqt+u9BM1sRKiCFz0V6vUwThSiyqu0A==
Okay, thanks Sebastien and Andreas!
Adam Getchell
about.me/adamgetchell
> On Apr 28, 2016, at 12:54 PM, Sebastien Loriot (GeometryFactory)
> wrote:
> On 04/28/2016 09:50 PM, Andreas Fabri wrote:
>> std::vector<Vertex_handle> V(t.finite_vertices_begin(),
>> finite_vertices_end());
>> or the same with std::vector::insert(b.e)
> @Andreas I guess you meant std::vector<Vertex>.
> @Adam, since Finite_vertex_iterator is convertible to Vertex_handle
> you need a tranform_iterator that do not dereference the iterator.
> Better do a classic for-loop
> Sebastien.
>> andreas
>> On 28/04/2016 21:26, Adam Getchell wrote:
>>> Hi all,
>>> Just in case I missed it in the documentation, is there a method which
>>> pushes all finite_vertices into a std::vector<Vertex_handle>?
>>> (I know it’s trivial to write with the Finite_vertex_iterator, checking
>>> to see if I even need that.)
>>> Adam Getchell
>>> about.me/adamgetchell <http://about.me/adamgetchell>
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Method for populating container with finite_vertices?, Adam Getchell, 04/28/2016
- Re: [cgal-discuss] Method for populating container with finite_vertices?, Andreas Fabri, 04/28/2016
- Re: [cgal-discuss] Method for populating container with finite_vertices?, Sebastien Loriot (GeometryFactory), 04/28/2016
- Re: [cgal-discuss] Method for populating container with finite_vertices?, Adam Getchell, 04/28/2016
