cgal-discuss - Re: [cgal-discuss] Intersecting Arrangement_2's edges
  • To:
  • Subject: Re: [cgal-discuss] Intersecting Arrangement_2's edges
  • Date: Tue, 17 May 2016 16:26:30 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:OweFpRRkwQ1UmRvqFju5i765Ztpsv+yvbD5Q0YIujvd0So/mwa65ZRON2/xhgRfzUJnB7Loc0qyN4/GmAzxLvs/JmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviqtuJM04X3XKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQqIjULYNDCg6K3tno4rwpBzbRE2O4GEdWyMYiF1TEg3d5Vb7WJn29SD1v+441CiBNtDtVuMIXmGp4K5vDRPpkywaLCUR8WfNi8U2grgIjgimokk1+IPeaZqJNfd4NofaZ9IdWSIBcctWUiFdGJKSZoATCPAQfKwQ+5L5oEEPqgf4AA2EC+bmyzsOjXjzi/5pm989GB3LiVRzV+kFt27Z+Y34
Sorry I meant a minimal code example to see where the pb could be.
The problem was clear.
Sebastien.
On 05/17/2016 04:22 PM, Everton Constantino wrote:
Hi Sebastien,
you can find a file at http://braindump.com.br/arr.pdf with sets of 3
images, one is a map of roads, the 'raw' shows the computed visibility
Arrangement (for the point on the image, there's also a not shown square
drawn around the point) and the other shows the intersection of edges
form by the roads and the visibility region.
What I want to do is to calculate the roads that belong to the
visibility of a certain point. You will notice that some roads that are
present both on the 'raw' image and on the full map are not present on
the intersection.
The way I'm calculating right now is iterating through edges of both
arrangements and comparing source() and target() points (since they are
directed segments I compare both directions because I don't care).
Hope that clarifies something.
Thanks,
E.
On 16:02, Sebastien Loriot (GeometryFactory) wrote:
Please share a minimal example showing what is not working correctly.
Thanks,
Sebastien.
On 05/17/2016 03:52 PM, Everton Constantino wrote:
Hi,
I'm trying to intersect two Arrangement_2 edge's but iterating through
both sets of edges and checking the source(), target() is not only slow
but wrong (some edges are missing). Is there a canonical way to do this?
Thanks,
