cgal-discuss - Re: [cgal-discuss] Intersecting Arrangement_2's edges
  • To:
  • Subject: Re: [cgal-discuss] Intersecting Arrangement_2's edges
  • Date: Tue, 17 May 2016 18:57:33 -0300
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hi Efi,
thanks for the tips, the overlay gives the opposite of what I want,
sorry I should have made myself clearer I meant union and intersection
as set theoretic words. Anyway you sorta gave me the path, I'm iterating
edges, getting the associated curve and using Kernel::Intersect_2. Now
everything is working as intended.
Best regards,
E.
On 23:50, Efi Fogel wrote:
> Hi Everton,
> 1. The equivalent of the '==' operator is the 'Equal_2' functor; see
> http://doc.cgal.org/latest/Arrangement_on_surface_2/classArrTraits_1_1Equal__2.html
> 2. The overlay gives you the overlay. What do you mean by 'union of
> arrangements' or 'intersection of arrangements'?
> Best,
> Efi
> ____ _ ____ _
> /_____/_) o /__________ __ //
> (____ ( ( ( (_/ (_/-(-'_(/
> _/
> On Tue, May 17, 2016 at 9:40 PM, Everton Constantino <
> wrote:
> > Hi Efi,
> > reading CGAL's documentation I failed to find the definition of the ==
> > operator for edges so I ended up using brute force. The overlay free
> > function gives me the union of the arrangements (I dunno if there's an
> > option for the intersection).
> > Thanks,
> > E.
> > On 21:14, Efi Fogel wrote:
> > > I'm not sure why you compare points but say that you intend to intersect
> > > edges, but it seems to me that you should use the overlay() free
> > function;
> > > see, e.g.,
> > http://doc.cgal.org/latest/Arrangement_on_surface_2/group__PkgArrangement2Funcs.html#gaddb9e44b14b27e4cf0c7bb26b27d8518
> > > Also, notice that the traits contains a predicate that compares two
> > points.
> > > You should use it instead of the '==' operator.
> > > ____ _ ____ _
> > > _/
> > > On Tue, May 17, 2016 at 8:45 PM, Everton Constantino <
> > > wrote:
> > > > So, changing the algorithm as you mentioned I realised something. One
> > > > edge on a Arrangement might represent the same line as several edges
> > > > on
> > > > the other or, even worse, one edge of an Arrangement might contain
> > > > several edges of the other and even more so my way of checking the
> > > > intersection fails.
> > > > What I think I should be doing is to check which segments of one
> > > > arrangement are contained in the other not edges in particular. I know
> > a
> > > > naive, brute force, way to solve this. Do I have something in CGAL
> > > > that
> > > > could help me?
> > > > E.
> > > > On 18:14, Sebastien Loriot (GeometryFactory) wrote:
> > > > > One way to speed things up is to put arrangement edges in a
> > > > > std::set<
> > > > > std::pair<vertex_handle,vertex_handle> > with a custom less functor
> > > > > comparing the points of the vertices (if you don't care about
> > > > > orientation then also sort the pair before insertion).
> > > > > You can then use the set for queries.
> > > > > About the missing edges, it would be interesting to see those
> > missing.
> > > > > Did you try another visibility algorithm provided in CGAL, just so
> > see
> > > > > if the results are the same?
> > > > > Sebastien.
> > > > > On 05/17/2016 05:50 PM, Everton Constantino wrote:
> > > > > > The source is on github https://github.com/everton1984/Malex the
> > file
> > > > is
> > > > > > src/get_chunks.cpp. Thanks for the == tip, I already started using
> > it
> > > > > > btw.
> > > > > > The data, unfortunately, is private and I can't share it.
> > > > > > E.
> > > > > > On 17:17, Sebastien Loriot (GeometryFactory) wrote:
> > > > > > > We're looking for a pb here. If we can't see a full example
> > > > > > > (in particular the typedefs) and try compiling it to reproduce
> > the
> > > > > > > issue it is harder to help because we can only guess.
> > > > > > > I know it is some extra work but it is needed if you want to
> > maximize
> > > > > > > the chances to get an answer.
> > > > > > > Sebastien.
> > > > > > > PS: Note that operator==()(Point_2, Point_2) is implemented in
> > CGAL.
> > > > > > > On 05/17/2016 04:59 PM, Everton Constantino wrote:
> > > > > > > > Oh ok, here is the part where I do the intersection:
> > > > > > > > Arrangement_2 res;
> > > > > > > > vector<Kernel::Segment_2> bounding_roads;
> > > > > > > > for( Edge_const_iterator eit = output_arr.edges_begin(); eit
> > > > output_arr.edges_end(); ++eit){
> > > > > > > > bool found = false;
> > > > > > > > for( Edge_const_iterator envit = env.edges_begin();
> > envit !=
> > > > env.edges_end() && !found; ++envit ){
> > > > > > > > if( envit->source()->point().x() ==
> > > > eit->source()->point().x() &&
> > > > > > > > envit->source()->point().y() ==
> > > > eit->source()->point().y() &&
> > > > > > > > envit->target()->point().x() ==
> > > > eit->target()->point().x() &&
> > > > > > > > envit->target()->point().y() ==
> > > > eit->target()->point().y() ){
> > > > > > > > found = true;
> > > > > > > > }else if(envit->source()->point().x() ==
> > > > eit->target()->point().y() &&
> > > > eit->source()->point().y() ){
> > > > > > > > found = true;
> > > > > > > > if( found ) {
> > > > > > > > Kernel::Segment_2 seg( eit->source()->point(),
> > > > eit->target()->point() );
> > > > > > > > bounding_roads.push_back(seg);
> > > > > > > > CGAL::insert(res, bounding_roads.begin(),
> > bounding_roads.end());
> > > > > > > > On 16:26, Sebastien Loriot (GeometryFactory) wrote:
> > > > > > > > > Sorry I meant a minimal code example to see where the pb
> > could
> > > > be.
> > > > > > > > > The problem was clear.
> > > > > > > > > Sebastien.
> > > > > > > > > On 05/17/2016 04:22 PM, Everton Constantino wrote:
> > > > > > > > > > Hi Sebastien,
> > > > > > > > > > you can find a file at http://braindump.com.br/arr.pdf
> > with
> > > > sets of 3
> > > > > > > > > > images, one is a map of roads, the 'raw' shows the
> > > > > > > > > > computed
> > > > visibility
> > > > > > > > > > Arrangement (for the point on the image, there's also a
> > > > > > > > > > not
> > > > shown square
> > > > > > > > > > drawn around the point) and the other shows the
> > intersection
> > > > of edges
> > > > > > > > > > form by the roads and the visibility region.
> > > > > > > > > > What I want to do is to calculate the roads that belong to
> > the
> > > > > > > > > > visibility of a certain point. You will notice that some
> > roads
> > > > that are
> > > > > > > > > > present both on the 'raw' image and on the full map are
> > > > > > > > > > not
> > > > present on
> > > > > > > > > > the intersection.
> > > > > > > > > > The way I'm calculating right now is iterating through
> > edges
> > > > of both
> > > > > > > > > > arrangements and comparing source() and target() points
> > (since
> > > > they are
> > > > > > > > > > directed segments I compare both directions because I
> > > > > > > > > > don't
> > > > care).
> > > > > > > > > > Hope that clarifies something.
> > > > > > > > > > Thanks,
> > > > > > > > > > E.
> > > > > > > > > > On 16:02, Sebastien Loriot (GeometryFactory) wrote:
> > > > > > > > > > > Please share a minimal example showing what is not
> > working
> > > > correctly.
> > > > > > > > > > > Thanks,
> > > > > > > > > > > Sebastien.
> > > > > > > > > > > On 05/17/2016 03:52 PM, Everton Constantino wrote:
> > > > > > > > > > > > Hi,
> > > > > > > > > > > > I'm trying to intersect two Arrangement_2 edge's but
> > > > iterating through
> > > > > > > > > > > > both sets of edges and checking the source(), target()
> > is
> > > > not only slow
> > > > > > > > > > > > but wrong (some edges are missing). Is there a
> > canonical
> > > > way to do this?
> > > > > > > > > > > > Thanks,
> > > > > > > > > > > You are currently subscribed to cgal-discuss.
> > > > > > > > > > > To unsubscribe or access the archives, go to
> > > > > > > > > > > https://sympa.inria.fr/sympa/info/cgal-discuss
> > > > Everton R. Constantino
> > > > "Success is overrated"
Attachment: signature.asc
Description: PGP signature
