- To: "" <>
- Subject: Re: [cgal-discuss] vector of points
- Date: Sun, 22 May 2016 17:12:57 +0000 (UTC)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Thanks for the response.
Actually this code was just an example of what I'm going to do.
Because I want to make a delaunay triangulation, I must use an array(vector) of points, but later I want to manipulate the x and y of each point of the vector, how can I access them? in the case of one point it's: point.x() and point.y(), what about an array of points?
On Sunday, May 22, 2016 9:34 PM, Frédérik Paradis <> wrote:
You have to use the copy constructor like this:
points[0] = Point_2(1.0, 1.0);
Frédérik
2016-05-22 12:52 GMT-04:00 parisa rahmani <>:
Hi every one. I'm new to CGAL.I'm a little bit confused about using vector of points in CGAL.how can I have access to x and y elements of Point_2, I mean :typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel; typedef Kernel::Point_2 Point_2; typedef std::vector<Point_2> Vector; Vector points; points.reserve(5); int main(){ points[0].x() =1.0; points[0].y() =1.0; return 0;}
points[i].x() or points[i].x produces error.thanksParisa
- [cgal-discuss] vector of points, parisa rahmani, 05/22/2016
- Re: [cgal-discuss] vector of points, Frédérik Paradis, 05/22/2016
- Re: [cgal-discuss] vector of points, parisa rahmani, 05/22/2016
