- To:
- Subject: Re: [cgal-discuss] vector of points
- Date: Sun, 22 May 2016 13:25:03 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:qoF2gxEZY6P7Z2hlizp1ap1GYnF86YWxBRYc798ds5kLTJ75o8mwAkXT6L1XgUPTWs2DsrQf27uQ6PCrADVaqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7H0oM2YOlwSzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzQrVcSTgnKGso/9bDtB/ZTALJ6GFPfH8Rl09mGYnJbQv7Xd/JuzHzuutmkH2UJcTsROhpCRy/6Lt3QQDhziwOYW1quFrLg9B92foI6CmqoAZyltbZ
I never used the delaunay triangulation so I don't know if there is anything special with it. But, in the general case, if you want to modify a point, you could do something like that:
point[i] = Point_2(point[i].x() + 1, point[i].y())
if you wanted for instance to translate the point of 1 unit on the x-axis.
Frédérik
2016-05-22 13:12 GMT-04:00 parisa rahmani <>:
Thanks for the response.Actually this code was just an example of what I'm going to do.Because I want to make a delaunay triangulation, I must use an array(vector) of points, but later I want to manipulate the x and y of each point of the vector, how can I access them? in the case of one point it's: point.x() and point.y(), what about an array of points?
You have to use the copy constructor like this:points[0] = Point_2(1.0, 1.0);
Frédérik
2016-05-22 12:52 GMT-04:00 parisa rahmani <>:Hi every one. I'm new to CGAL.I'm a little bit confused about using vector of points in CGAL.how can I have access to x and y elements of Point_2, I mean :typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel; typedef Kernel::Point_2 Point_2; typedef std::vector<Point_2> Vector; Vector points; points.reserve(5); int main(){ points[0].x() =1.0; points[0].y() =1.0; return 0;}
points[i].x() or points[i].x produces error.thanksParisa
- [cgal-discuss] vector of points, parisa rahmani, 05/22/2016
- Re: [cgal-discuss] vector of points, Frédérik Paradis, 05/22/2016
- Re: [cgal-discuss] vector of points, parisa rahmani, 05/22/2016
