- To: "" <>
- Subject: RE: [cgal-discuss] mesh generation from levelset and preserving some things
- Date: Mon, 23 May 2016 10:06:13 +0000
- Accept-language: en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Thanks for the reply.
Ok, but do I have the warranty that the resulting mesh will be conforming (in
a weak sense of course, because of the remeshing process) to the boundary
(edges) of the polyhedral mesh.
I think this image (joint image) explain my problem.
I need the surface mesh to impose correctly boundary conditions
(pressure/displacement/...) in a subsequence FEM analysis.
Felipe
-----Message d'origine-----
De :
[mailto:]
De la part de Andreas Fabri
Envoyé : vendredi 20 mai 2016 10:37
À :
Objet : Re: [cgal-discuss] mesh generation from levelset and preserving some
things
Hello,
What we only understand now is, that you can accept a solution that remeshes
the polyhedral surface.
As a matter of fact it is possible to write a model of a mesh domain that
combines a polyhedral mesh domain and an image mesh domain.
It roughly boils down to a wrapper around two mesh domain classes that
interrogates both and returns a combination of the results.
GeometryFactory can help to work out the details or implement it.
Best,
Andreas
On 19/05/2016 23:28, BORDEU Felipe (SAFRAN) wrote:
> Ok, I understand the problem and the limitation of my approach.
> So if I understand well, I have to :
> 1) load my stl mesh (with Polyheron_3???) (info: the surface defined
> by the stl is not planar 3D surface)
> 2) remesh this surface with the " 3D surface mesh Generation"
> 3) load my levelset field (Done)
> 4) In some way force the 3D Mesh Generation to respect my surface mesh (or
> give the surface mesh as the starting triangulation).
> Is this possible???
> Thanks
> Felipe
> De :
> [mailto:]
> De la part de Laurent Rineau
> (CGAL/GeometryFactory) Envoyé : vendredi 22 avril 2016 10:38 À :
> Le Thursday 21 April 2016 15:18:12 BORDEU Felipe a écrit :
>> Thanks, but can you develop a little bit more your answer. Can I
>> convert (read from file) my mesh into a Cgal mesh object?.
> The mesh produces by CGAL needs geometrical properties, mainly the Delaunay
> criterion. If the mesh you want to preserve does not have that property,
> the only hope is to remesh it using the CGAL 3D mesh generator, and then
> there will be hope that you can write a custom mesh domain class, that
> allows to mix you mesh with the levelset.
>> Or maybe I can use the Line Features to impose the edges and the
>> points on the interface between domain to be meshed (levelset) and
>> my mesh so I get a compatible triangulation?
> If you do that, the lines, corresponding to the edges of the input mesh,
> will be remeshed, and even then there is no guarantee that the facets of
> the input mesh can be represented by union of Delaunay facets.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
" Ce courriel et les documents qui lui sont joints peuvent contenir des
informations confidentielles, être soumis aux règlementations relatives au
contrôle des exportations ou ayant un caractère privé. S'ils ne vous sont pas
destinés, nous vous signalons qu'il est strictement interdit de les
divulguer, de les reproduire ou d'en utiliser de quelque manière que ce soit
le contenu. Toute exportation ou réexportation non autorisée est interdite Si
ce message vous a été transmis par erreur, merci d'en informer l'expéditeur
et de supprimer immédiatement de votre système informatique ce courriel ainsi
que tous les documents qui y sont attachés."
" This e-mail and any attached documents may contain confidential or
proprietary information and may be subject to export control laws and
regulations. If you are not the intended recipient, you are notified that any
dissemination, copying of this e-mail and any attachments thereto or use of
their contents by any means whatsoever is strictly prohibited. Unauthorized
export or re-export is prohibited. If you have received this e-mail in error,
please advise the sender immediately and delete this e-mail and all attached
documents from your computer system."
Description: Capture.PNG
- RE: [cgal-discuss] mesh generation from levelset and preserving some things, BORDEU Felipe (SAFRAN), 05/19/2016
- Re: [cgal-discuss] mesh generation from levelset and preserving some things, Andreas Fabri, 05/20/2016
- RE: [cgal-discuss] mesh generation from levelset and preserving some things, BORDEU Felipe (SAFRAN), 05/23/2016
