cgal-discuss - Re: [cgal-discuss] mesh generation from levelset and preserving some things
  • To:
  • Subject: Re: [cgal-discuss] mesh generation from levelset and preserving some things
  • Date: Fri, 20 May 2016 10:36:52 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:a613wxzJIOk5WjrXCy+O+j09IxM/srCxBDY+r6Qd0e8QIJqq85mqBkHD//Il1AaPBtWKrakfwLOO7+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6DyZ/snLnqp9X6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqrze+E0TKdTES89G2Ez/szi8xfZHiWV4X5Je2MaiBdBGEDr5RvgX9+luy32rOd0w2+UNMfsTJg7VDOn4rtxWRHhgzsALS9/+2bS3J8jxJlHqQ6s8kQsi7XfZ5uYYaJz
Hello,
What we only understand now is, that you can accept a solution
that remeshes the polyhedral surface.
As a matter of fact it is possible to write a model of a mesh domain
that combines a polyhedral mesh domain and an image mesh domain.
It roughly boils down to a wrapper around two mesh domain
classes that interrogates both and returns a combination of
the results.
GeometryFactory can help to work out the details or implement it.
Best,
Andreas
On 19/05/2016 23:28, BORDEU Felipe (SAFRAN) wrote:
Ok, I understand the problem and the limitation of my approach.
So if I understand well, I have to :
1) load my stl mesh (with Polyheron_3???) (info: the surface defined by the
stl is not planar 3D surface)
2) remesh this surface with the " 3D surface mesh Generation"
3) load my levelset field (Done)
4) In some way force the 3D Mesh Generation to respect my surface mesh (or
give the surface mesh as the starting triangulation).
Is this possible???
Thanks
Felipe
-----Message d'origine-----
De :
[mailto:]
De la part de Laurent Rineau (CGAL/GeometryFactory)
Envoyé : vendredi 22 avril 2016 10:38
À :
Objet : Re: [cgal-discuss] mesh generation from levelset and preserving some
things
Le Thursday 21 April 2016 15:18:12 BORDEU Felipe a écrit :
Thanks, but can you develop a little bit more your answer. Can I
convert (read from file) my mesh into a Cgal mesh object?.
The mesh produces by CGAL needs geometrical properties, mainly the Delaunay
criterion. If the mesh you want to preserve does not have that property, the
only hope is to remesh it using the CGAL 3D mesh generator, and then there
will be hope that you can write a custom mesh domain class, that allows to
mix you mesh with the levelset.
Or maybe I can use the Line Features to impose the edges and the
points on the interface between domain to be meshed (levelset) and my
mesh so I get a compatible triangulation?
If you do that, the lines, corresponding to the edges of the input mesh, will
be remeshed, and even then there is no guarantee that the facets of the input
mesh can be represented by union of Delaunay facets.
Laurent Rineau, PhD
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
