- To:
- Subject: Re: [cgal-discuss] Nef polygon traversal
- Date: Wed, 25 May 2016 04:50:16 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:Nhj8qBezDkBW6i2TL3p9jTBklGMj4u6mDksu8pMizoh2WeGdxc65Zh7h7PlgxGXEQZ/co6odzbGG4ua8AidcvN6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDjvcGIKFkVzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzQrVcSTgnKGso/9bDtB/ZTALJ6GFPfH8Rl09uChLY9xj5X9+lojbxprIt8CafNMzyC7szXGLxvO9QVBb0hXJfZHYC+2bNh5kogQ==
After read the source code in CGAL\IO\Qt_widget_Nef_2.h, especially the
following function:
CGAL::Qt_widget& operator<<(CGAL::Qt_widget& ws, const Nef_polyhedron_2<T>&
P);
I think the way I did in the last post is pretty much the same. So again I'd
like to know what is going wrong? Thanks very much.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Nef-polygon-traversal-tp4661962p4661963.html
- [cgal-discuss] Nef polygon traversal, 许春旭, 05/25/2016
- Re: [cgal-discuss] Nef polygon traversal, Narusaki, 05/25/2016
- Re: [cgal-discuss] Nef polygon traversal, Narusaki, 05/26/2016
