- To: "" <>,
- Subject: [cgal-discuss] CGAL @ Siggraph
- Date: Sun, 10 Jul 2016 18:46:14 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:SgLTAx9GIA+tef9uRHKM819IXTAuvvDOBiVQ1KB80+8cTK2v8tzYMVDF4r011RmSDN2dsK4P0rKN+4nbGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2WVTerzWI4CIIHV2nbEwud7yzQdKZ1pzsn8mJuLTrKz1SgzS8Zb4gZD6Xli728vcsvI15N6wqwQHIqHYbM85fxGdvOE7B102kvpT4r9Zf9HEasP0o84tMUL7xYr8jZb1eFjUvdW4vroW/vhbKSU6D52AXT34NuhtOGQnMqh/gCNO5vSb9s+dhwjiCJ8r9QKsvWDKtx6ZtUh7hzikdZBAj92SCo8p8lq9Su1qPrhZlwsaAaYeZLvd3ZeXTdNkAREJOU8FUWjBbE421ZJcIFftHNuFd+dqu72ASpAezUFH/TNjkzSVF0yf7
Hello,
Siggraph 2016 in Anaheim is getting closer. This year, we are
not only on the exhibition floor with the CGAL booth, but
we offer a 1.5h course on Tuesday 26 July, 9-10:30 am
The goal of the course is not so much to present all algorithms,
but more to show how they can be adapted to user needs.
We explain "property maps" and an extension of the BGL "Graph"
concepts, which enables users, to run, for example, a CGAL
mesh segmentation algorithm directly on a mesh of OpenMesh,
without converting it to a mesh of CGAL.
In the course, we also address questions like licensing,
the project infrastructure, and how you can contribute
in case you have developed a fundamental data structure
or algorithm that you would like to see in CGAL.
See you in Anaheim,
Andreas Fabri & Pierre Alliez
- [cgal-discuss] CGAL @ Siggraph, Andreas Fabri, 07/10/2016
