- To:
- Subject: Re: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2
- Date: Sun, 10 Jul 2016 17:36:19 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:ybavrBOISwFL29CyYPUl6mtUPXoX/o7sNwtQ0KIMzox0KPjzrarrMEGX3/hxlliBBdydsKMczbGK+PG5EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuS9aU1Jj8hrn60qaQSj0AvCC6b7J2IUf+hiTqne5Sv7FfLL0swADCuHpCdrce72ppIVWOg0S0vZ/or9YwuxhX7vku/soFXaThdLkjVpRZCi4nOiY7/p7Frx7GGCKJ6mERW35evBNCGQmNuBj8Uo38uzC8uON3wiiyMsDxSL0oQyWs5qx3TwX5ziwAMmhqoynslsVsgfcD81qarBtlztuMbQ==
Instructions for bug reports are here:
http://www.cgal.org/bug_report.html
Best,
Andreas
On 09/07/2016 12:07, Marc Glisse wrote:
On Sat, 9 Jul 2016, Grzegorz JABLONSKI wrote:
The same error occurs, when I use Alpha_shape_vertex_base_2:
Please don't post those random lists of typedefs, always post a MCVE
(minimum complete verifiable example), that is:
* include the #includes and the instanciation (I should be able to
copy-paste, compile, and immediatly get the same error)
* remove anything irrelevant like Point
You still don't seem to be using Alpha_shape_vertex_base_2, the Vb
typedef is not used anywhere.
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Grzegorz JABLONSKI, 07/08/2016
- Re: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Marc Glisse, 07/08/2016
- RE: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Grzegorz JABLONSKI, 07/09/2016
- RE: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Marc Glisse, 07/09/2016
- Re: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Andreas Fabri, 07/10/2016
