- To:
- Subject: Re: [cgal-discuss] Intersection between segment and polygon
- Date: Thu, 28 Jul 2016 11:12:20 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:7mPlMBHSpHLZNeXkd9TKBZ1GYnF86YWxBRYc798ds5kLTJ75pMuwAkXT6L1XgUPTWs2DsrQf2rKQ7f+rADVIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWD14LpiKvrotX6WEZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwu3cYh/V0/MFJVeD2fr8zUKdDJDUgKWE8osPx5jfZSg7a3nwYGkARlAHTSzDY9g1/FsP1tjb8v6x73zeTFcLzRLEwHz+l6vE4G1fTlC4bOmthoynsgctqgfcDrQ==
I remember reading another post claiming a two point degenerate polygon had some issues since one of the latest cgal versions. I couldn't find it again thought, so I might be utterly wrong.
The issue is that I have rays as well, which I can't turn into a degenerate polygon. I'll just take the iteration approach then.
On Thu, Jul 28, 2016 at 11:02 AM, Monique Teillaud <> wrote:
On 28 Jul 2016, at 10:31, Pol Monsó Purtí <> wrote:CGAL::intersect and do_intersect take segments, rays, squares... but not polygon_2.Indeed, because intersect is in the CGAL Kernel(s), which only handle(s) constant-size objects, by definition.And the reverse for Polygon_2 intersection functions, who only takes polygons.How do you usually solve this, iterating over the segments of the polygon + checking if the ends are inside?Sounds reasonable.Alternatively, if you want to use the intersection function of polygons, you can also create another polygon from the two vertices of the segment, then intersect the two polygons. Not sure about efficiency (I don’t precisely know how the intersection of 2 polygons is implemented).--Monique Teillaud
https://members.loria.fr/Monique.Teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
- [cgal-discuss] Intersection between segment and polygon, Pol Monsó Purtí, 07/28/2016
- Re: [cgal-discuss] Intersection between segment and polygon, Monique Teillaud, 07/28/2016
- Re: [cgal-discuss] Intersection between segment and polygon, Pol Monsó Purtí, 07/28/2016
