- To:
- Subject: Re: [cgal-discuss] return of nan value
- Date: Thu, 28 Jul 2016 16:47:24 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:XJFPPhV3AzK/dbnZdsLhTeG0whrV8LGtZVwlr6E/grcLSJyIuqrYZhKDt8tkgFKBZ4jH8fUM07OQ6PG4HzJfqsnf+Fk5M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLshrj0pcKYPFsArQH+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK71dqB9Qb1DByk9KEg04tfqvF/NV1ih/HwZBy8ymwdSDg7ZpCv7WJr4r2O6ncVU/G61MMrzQKwuSBqr5LtsUg6pwm9TMzck6mzRlopqjaRWqQ+JrBN2x8jTeo7DZ6k2Rb/UYd5PHTkJZc1WTSEUWo4=
Le Wednesday 27 July 2016 12:13:02 Wellington Castro a écrit :
> Hi everbody, I am using the function tree.closest_point(), but is returns a
> nan point, what it means ?
It might be that:
- your AABB tree contains flat triangles,
- you do not have CGAL assertions (probably a Release build).
Laurent Rineau, PhD
- [cgal-discuss] return of nan value, Wellington Castro, 07/27/2016
- Re: [cgal-discuss] return of nan value, Laurent Rineau (CGAL/GeometryFactory), 07/28/2016
- Re: [cgal-discuss] return of nan value, Wellington Castro, 07/28/2016
- Re: [cgal-discuss] return of nan value, Laurent Rineau (CGAL/GeometryFactory), 07/29/2016
