cgal-discuss - Re: [cgal-discuss] Example code for "Estimation of Local Differential Properties of Point-Sampled Surfaces"
  • To:
  • Subject: Re: [cgal-discuss] Example code for "Estimation of Local Differential Properties of Point-Sampled Surfaces"
  • Date: Mon, 22 Aug 2016 17:12:59 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:dRIzyh0jYjggm9JBsmDT+DRfVm0co7zxezQtwd8ZsegRLPad9pjvdHbS+e9qxAeQG96KsrQf0aKW6/mmAj1Yp87Z8TgrS99lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLHrvcaJK0UQ3XzmMOs0dE335Szq9eAuybN4Lagwzhab6lBpQM9xgV1SGFSIghzn7d2x9pMwuw5ZuvYm6tISGf6iJ/dwHvRkC2EtPGkxocHqrhLeVhCn530GU2xQnAAbLRLC6USwZZr7uzDmt+d7kA2dJ8zxUfh0djml6qp3Ug7GgSwbMCQosSuf3td0i7hapw7nohhXzIvdYYXTP/17KPCONegGTHZMC54CHxdKBZmxOtMC
The class Monge_via_jet_fitting has 3 template parameters
and you only provided one.
http://doc.cgal.org/latest/Jet_fitting_3/classCGAL_1_1Monge__via__jet__fitting.html
Sebastien.
On 08/03/2016 11:17 AM, Kelvin_Piroddi wrote:
Hi
I am trying to run the example code for:
Jet_fitting_3/Single_estimation.cpp
The typedef's are:
typedef double DFT;
typedef CGAL::Simple_cartesian<DFT> Data_Kernel;
typedef Data_Kernel::Point_3 DPoint;
typedef CGAL::Monge_via_jet_fitting<Data_Kernel> My_Monge_via_jet_fitting;
typedef My_Monge_via_jet_fitting::Monge_form My_Monge_form;
My errors are:
error: C2976: 'CGAL::Monge_via_jet_fitting': too few template arguments
error: C2955: 'CGAL::Monge_via_jet_fitting': use of class template requires
template argument list
I am not sure why i am getting theses errors?
Thank you
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Example-code-for-Estimation-of-Local-Differential-Properties-of-Point-Sampled-Surfaces-tp4662125.html
