- To:
- Subject: Re: [cgal-discuss] Methods to remove degenerate segments of a Polygon_2?
- Date: Mon, 22 Aug 2016 17:17:10 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:mS0QRhe/y/7YfsO26v1sdL2RlGMj4u6mDksu8pMizoh2WeGdxc69Yh7h7PlgxGXEQZ/co6odzbGH6ua7AyRAuc/H6yFaNsQUFlcssoY/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbtr8FoOatcmrzef6o8SVOFQRwmHnKfMqdVPt/F2X7pFXyaJZaY8JgiPTpXVJf+kEjUhJHnm02yjG28Gr4ZR4+D5Rsf9yv+RJUKH9YrhqBecAVGduYCgJ45jguhDHCAeO/XABSX4+kxxSAgGD4gupcI32t36wjed30TKGPMDwBZQzQzWl8+8rZxLvjSobLS8X+WrLjdZhzegT9AmloAZ+xJKSZYW9O/93f6ebdtQfEzkSFv1NXjBMV9vvJ7AECPAMaL5V
On 08/12/2016 12:58 PM, Pol Monsó Purtí wrote:
Is there a method to remove the repeated vertices on a Polygon_2?To be safe you must increment the iterator before remove the previous one.
What happens if I remove them within a circulator? Should I substract
one to the circulator?
Is it better to build a new polygon and then copy-construct the original
one?
Something like:
polygon.erase(vit++);
Sebastien.
- [cgal-discuss] Methods to remove degenerate segments of a Polygon_2?, Pol Monsó Purtí, 08/12/2016
- Re: [cgal-discuss] Methods to remove degenerate segments of a Polygon_2?, Sebastien Loriot (GeometryFactory), 08/22/2016
