cgal-discuss - Re: [cgal-discuss] mesh boundary exactly on circle
  • To:
  • Subject: Re: [cgal-discuss] mesh boundary exactly on circle
  • Date: Mon, 22 Aug 2016 17:23:47 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:k2jzuR1l5ZzrcDCGsmDT+DRfVm0co7zxezQtwd8ZsegeKPad9pjvdHbS+e9qxAeQG96KsrQf0aGO6OigATVGusfZ9ihaMdRlbFwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oMyKJV4Sz2LmKfMqdVPt/F2X7pFXyaJZaY8JgiPTpXVJf+kEjUhJHnm02yjG28Gr4ZR4+D5Rsf9yv+RJUKH9YrhqBecAVGduYCgJ45jguhDHCAeO/XABSX4+kxxSAgGD4gupcI32t36wjed30TKGPMDwBZQzQzWl8+8rZxLvjSobLS8X+WrLjdZhzegT9AmloAZ+xJKSZYW9O/93f6ebdtQfEzkSFv1NXjBMV9vvJ7AECPAMaL5V
On 08/17/2016 11:51 AM, Nico Schlömer wrote:
I'd like to generate a mesh on a circle, and all the boundary points are
required to sit exactly on it. So far, I can only see how to generate
meshed which are bounded by polygons [1]; here you insert linear contraints.
Any hints?
Cheers,
Nico
[1] http://doc.cgal.org/latest/Mesh_2/
Start by generating a 1D meshing of the circle matching the size criteria, create a 2D Constrained triangulation (starting by inserting the circle center to avoid performance issues) and then run the meshing.
This will works because all constrained edges in your mesh are already
Gabriel and also won't be refined since they match the size criteria.
Sebastien.
