cgal-discuss - Re: [cgal-discuss] Mesh Segmentation Trouble
  • To:
  • Subject: Re: [cgal-discuss] Mesh Segmentation Trouble
  • Date: Mon, 22 Aug 2016 17:20:41 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:2bSB4RReg2h4Z/HXTLkJRO8Ev9psv+yvbD5Q0YIujvd0So/mwa64YxKN2/xhgRfzUJnB7Loc0qyN4vmmAjZIoc7Y9itTKNoUD15NoP5VtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdazLE4Lfx/66y/q1s8WKJV4Z3XzmO/sydEzw9lSJ8JFOwMNLEeUY8lPxuHxGeuBblytDBGm4uFLC3Pq254Np6C9KuvgspIZqWKT+eLkkH/QDVGx1ezN92Mq+vhbKSU6D52AXT34NuhtOGQnMqh/gDbnrtS6v/NFw0iCBIcz7S/gQXi6j6LsjCDDljyIKKyQo3mjclstqneMR6Ea6oxtlwonIJoSRHPV7d6LZO9gdQDwSDY5qSyVdD9bkPMM0BO0bMLMAog==
I tried using the polyhedron demo on the elephant model, selecting 6
clusters and got something that is similar to the first image in the
documentation. What did you try?
Sebastien.
On 08/14/2016 03:20 PM, Pablo Sánchez wrote:
Hi,
Lately I've been working with CGAL's mesh segmentation functionalities
and I'm having some problems achieving different segmentations through
number_of_clusters and smoothing_lambda parameters.
I'm using your "elephant.off" mesh as an example, and as I try to get
the results you expose in your documentation for Surface Mesh
Segmentation, I'm not able to get the same kind of segmentation.
Even though I change the values of the parameters, I still get the same
segmentation in every iteration.
Could I get a hint of what I'm doing wrong?
Regards,
Pablo Sánchez
