cgal-discuss - Re: [cgal-discuss] Merging two surface meshes
  • To:
  • Subject: Re: [cgal-discuss] Merging two surface meshes
  • Date: Mon, 22 Aug 2016 17:25:08 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:eKGCMxBMihHgXyxeoGtlUyQJP3N1i/DPJgcQr6AfoPdwSP7zpcbcNUDSrc9gkEXOFd2CrakV0qyN6eu4AiRAuc/H6yFaNsQUFlcssoY/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbtr8FoOatcmrzef6o8SVOFQRwmHnKuspZFXu9EOK55FQ2dMjYo8KiTLx6kNSfOpXwW46bXmypD3bovmKwZh47i5LsOgg/cMTGY/zfqA/UKAKRG9+azN9t4XXskzIQgKLo3cdSW4LiQFgAg7f7Ri8UI2inDH9s7834ySQNNbqTL0yERCl9aZsVFeopyoAMjMl6nD5g8dsi7hK4Vjp8wd7xJTVZ53TMf5WcabUfNdcTm1ECJUCHxddC5+xOtNcR9EKOvxV+tHw
The output won't be manifold and no data structure in CGAL is able
to store this kind of data. What output do you expect?
Sebastien.
On 08/18/2016 02:42 PM, NGO Tri Dat wrote:
Hello,
I’d like to know how to merge two separated surface meshes [1] of
2D-in-3D polygons sharing a common segment as in the attached figure.
Any hint or suggestions will be greatly appreciated.
Kind regards,
Tri Dat Ngo
[1] http://doc.cgal.org/latest/Surface_mesh/index.html
__________________________
/Avant d'imprimer, pensez à l'environnement ! Please consider the
environment before printing ! /
/Ce message et toutes ses pièces jointes sont confidentiels et établis à
l'intention exclusive de ses destinataires. Toute utilisation non
conforme à sa destination, toute diffusion ou toute publication, totale
ou partielle, est interdite, sauf autorisation expresse. IFP Energies
nouvelles décline toute responsabilité au titre de ce message. This
message and any attachments are confidential and intended solely for the
addressees. Any unauthorised use or dissemination is prohibited. IFP
Energies nouvelles should not be liable for this message./
