cgal-discuss - Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes
  • To:
  • Subject: Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes
  • Date: Thu, 25 Aug 2016 13:50:34 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:mH4vwR0v74ZfLvFBsmDT+DRfVm0co7zxezQtwd8ZsekVL/ad9pjvdHbS+e9qxAeQG96KsrQf26GK6+igATVGusfZ9ihaMdRlbFwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oMyKJV4Yz2blKfMqdVPt/F2X7pFXyaJZaY8JgiPTpXVJf+kEjUhJHnm02yjG28Gr4ZR4+D5Rsf9yv+RJUKH9YrhqBecAVGduYCgI4tb2v0zDUReX/SlbFX4HlwJBRQnD9hDzGJnr9TDrs/J0nyicM8qxRr89XXGu7rxgVQTz2xsAYjU2+WWShs1rh79AuzqgoQZ+ysjaetK7Lv17K+nmcNkTXnZAU8AZcytbA4SgJ8sgAu0EMPpCvqf0rEcJtwr/T0H4H+fo0D5Pmjnz2YU11u0gFUfN2wl2TIFGi2jdsNigbPRaauuy1qSdlTg=
In the example you refer too, meshes were store individually without any
specify information about the connectivity. The different model were
simply meshed together so that the interface is common.
One solution is to enrich you structure so that each halfedge might
have a corresponding halfedge in another mesh. In case you have more
than two meshes sharing an edge, you'll need to short them out.
Sebastien.
On 08/22/2016 05:42 PM, NGO Tri Dat wrote:
Hi Sebastien,
You are right, the expected output is really non-manifold.
My example is very close to:
http://geometryfactory.com/portfolio/fracture-mesh-generation/
The objective is to simulate transport and flow in fracture network on such
non-manifold grid.
Do you know any solution for my problem? Thank you very much.
Kind regards,
Tri Dat
-----Message d'origine-----
De :
[mailto:]
De la part de Sebastien Loriot (GeometryFactory)
Envoyé : lundi 22 août 2016 17:25
À :
Objet : [PRUDENCE_MESSAGE_SUSPECT]Re: [cgal-discuss] Merging two surface
meshes
The output won't be manifold and no data structure in CGAL is able to store
this kind of data. What output do you expect?
Sebastien.
On 08/18/2016 02:42 PM, NGO Tri Dat wrote:
Hello,
I’d like to know how to merge two separated surface meshes [1] of
2D-in-3D polygons sharing a common segment as in the attached figure.
Any hint or suggestions will be greatly appreciated.
Kind regards,
Tri Dat Ngo
[1] http://doc.cgal.org/latest/Surface_mesh/index.html
__________________________
/Avant d'imprimer, pensez à l'environnement ! Please consider the
environment before printing ! / /Ce message et toutes ses pièces
jointes sont confidentiels et établis à l'intention exclusive de ses
destinataires. Toute utilisation non conforme à sa destination, toute
diffusion ou toute publication, totale ou partielle, est interdite,
sauf autorisation expresse. IFP Energies nouvelles décline toute
responsabilité au titre de ce message. This message and any
attachments are confidential and intended solely for the addressees.
Any unauthorised use or dissemination is prohibited. IFP Energies
nouvelles should not be liable for this message./
Avant d'imprimer, pensez à l'environnement ! Please consider the environment
before printing !
Ce message et toutes ses pièces jointes sont confidentiels et établis à
l'intention exclusive de ses destinataires. Toute utilisation non conforme à
sa destination, toute diffusion ou toute publication, totale ou partielle,
est interdite, sauf autorisation expresse. IFP Energies nouvelles décline
toute responsabilité au titre de ce message. This message and any attachments
are confidential and intended solely for the addressees. Any unauthorised use
or dissemination is prohibited. IFP Energies nouvelles should not be liable
for this message.
