- To:
- Subject: [cgal-discuss] Compute line angle in Epeck
- Date: Fri, 26 Aug 2016 02:20:35 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=PermError ; spf=None
- Ironport-phdr: 9a23:H+5kGRXwM4uJkwfxAEwpjWGtwqzV8LGtZVwlr6E/grcLSJyIuqrYZRODt8tkgFKBZ4jH8fUM07OQ6PG5HzdRqs/d6ThCKMUKDEBVz51O3kQJO42sNw7SFLbSdSs0HcBPBhdO3kqQFgxrIvv4fEDYuXao7DQfSV3VPAtxIfnpSMaJ15zkn7P6x5qGaApBgH+xYKh5MQ6thQTXrMgfx4V4eYgrzR6cjnJNeulQjU9vOEnbyxr148a9+thv2z9Wsuoi9sgGX7+sLPdwdqBREDlzazN938bsrxSWFQY=
Hi,
I'm using Epeck and I need to process average between two lines. Of course,
for this particular aim, there are several cases to predict but I'm blocked
because I have to process angle between the two lines in Epeck and I don't
find a solution to do it without converting Epeck Kernel in another Kernel.
Is there a possibility to process angle in Epeck?
Cheers,
Damien
Damien Dous
Snapkin Co-founder & CTO
www.snapkin.fr
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Compute-line-angle-in-Epeck-tp4662166.html
- [cgal-discuss] Compute line angle in Epeck, Damien Dous, 08/26/2016
- Re: [cgal-discuss] Compute line angle in Epeck, Marc Glisse, 08/26/2016
- Re: [cgal-discuss] Compute line angle in Epeck, Damien Dous, 08/26/2016
