cgal-discuss - Re: [cgal-discuss] Compute line angle in Epeck
  • To:
  • Subject: Re: [cgal-discuss] Compute line angle in Epeck
  • Date: Fri, 26 Aug 2016 13:08:26 +0200 (CEST)
On Fri, 26 Aug 2016, Damien Dous wrote:
In fact, I'm trying to process the average line between two almost parallele
lines.
You still didn't define what the average of 2 lines is...
Yes that is true, but my lines have not there vector unitarize and I don't
know how to unitarize these vectors.
Is it a solution for this?
If my guess of what "average" means is correct, you need at least a square root to compute it, so Epeck won't do. Epeck_with_sqrt would, if you can afford the slower running time. Only you know if some approximation of that line is sufficient.
Marc Glisse
