cgal-discuss - [cgal-discuss] Mesh_estimation.cpp -> Not measuring properties at all points
  • To:
  • Subject: [cgal-discuss] Mesh_estimation.cpp -> Not measuring properties at all points
  • Date: Tue, 30 Aug 2016 09:54:29 -0700 (PDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23:ns+SlxcnT743LpmhOGMIOwVnlGMj4u6mDksu8pMizoh2WeGdxc2yYh7h7PlgxGXEQZ/co6odzbGH6ua8BydZuc7J8ChbNscTB1ld0YRetjdjKfDGIHWzFOTtYS0+EZYKf35e1Fb/D3JoHt3jbUbZuHy44G1aMBz+MQ1oOra9QdaK3IyB/rvsqtiKO00I32LlIOA6EBLjpgrYsowagJBpN70q4hrPuHpBPepMlk1yIlfGhR/2457hrcUrpz5Zsfd4pp8bear/dqU8C7dfCWJ1YCgO+MT3uEyaHkO07XwGXzBNykJF
Hello,
I am using a variant of the code in Mesh_estimation.cpp (detailed in
http://doc.cgal.org/latest/Jet_fitting_3/index.html) to measure principal
curvatures at each vertex in a mesh. However, for certain meshes the program
will skip measuring the properties of a particular vertex. It is always the
same vertex that is skipped when I re-run the estimation on the same mesh.
What is going on here?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-estimation-cpp-Not-measuring-properties-at-all-points-tp4662192.html
  • [cgal-discuss] Mesh_estimation.cpp -> Not measuring properties at all points, rabm1993, 08/30/2016
