- To:
- Subject: Re: [cgal-discuss] failed to create straightSkeleton
- Date: Tue, 30 Aug 2016 17:28:20 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:ahFqGx2CcTCFL2jQsmDT+DRfVm0co7zxezQtwd8ZsegfLPad9pjvdHbS+e9qxAeQG96KsrQY1aGH6+igATVGusfZ9ihaMdRlbFwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oMyKJVkWz2vlKfMqdVPt/F2X7pFXyaJZaY8JgiPTpXVJf+kEjUhJHnm02yjG28Gr4ZR4+D5Rsf9yv+RJUKH9YrhqBecAVGduBUlvtZCu7UmLDVbXpyhUbmJDmRVBB03J7QrxQ4zqmir8rOt0nieAbuPsSrVhEw+v5a5wVB7ljm8jMCQ4932fyuN9i6dWvAiwiRV034nOccDffK5leqTHfNQGA29FdslUXi1FRIi7at1cXKI6Ie9Eotyl9BM1phykCFzxXO4=
I got the following assertion when trying to create the straight skeleton:
Expr: aPoly.is_simple() || !"The input polygon is not simple."
File: include/CGAL/create_straight_skeleton_2.h
Your polygon is not simple (intersection of boundary edges).
It is not a valid input which explain the issue you had.
Sebastien.
On 08/30/2016 03:28 PM, Marcos Dione wrote:
On Tue, Aug 30, 2016 at 02:16:40PM +0200, Sebastien Loriot (GeometryFactory)
wrote:
Could you provide the input polygon failing as an ascii file?
the original data comes from OSM:
http://www.openstreetmap.org/api/0.6/way/121897178/full
you'll find the WKT repr of the object attached.
- [cgal-discuss] failed to create straightSkeleton, Marcos Dione, 08/30/2016
- Re: [cgal-discuss] failed to create straightSkeleton, Sebastien Loriot (GeometryFactory), 08/30/2016
- Re: [cgal-discuss] failed to create straightSkeleton, Marcos Dione, 08/30/2016
- Re: [cgal-discuss] failed to create straightSkeleton, Sebastien Loriot (GeometryFactory), 08/31/2016
- Re: [cgal-discuss] failed to create straightSkeleton, Marcos Dione, 08/31/2016
