- To:
- Subject: Re: [cgal-discuss] Changed cells in Delaunay_triangulation_3
- Date: Mon, 5 Sep 2016 10:33:11 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:AnOQxhwTlx6HE0DXCy+O+j09IxM/srCxBDY+r6Qd0e0UIJqq85mqBkHD//Il1AaPBtSCra8UwLKP++C4ACpbsM7H6ChDOLV3FDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpqsSVPlUD3GP1Iesrak7n9UOJ7oheqLAhA5558gHOrHpMdrYe7kJTDnXXoSzB4Nyt9oVo6SVatqFp3cdBVaLnY/ZwFuQAX3x1e1wyscbkvB2GQQqU7WYHSU0XlABJCk7L9kLURJD05wnzsOc15C6HJ8vxTKt8DTar6aotVBj1kiEANiUR/2zQj8FslrNVqRm9oAZuhYXTZdfGZ7JFYqrBcIZCFiJ6VcFLWnkZDw==
Le 01/09/2016 à 11:48, Laurent Rineau (CGAL/GeometryFactory) a écrit :
Le Wednesday, August 31, 2016 3:50:41 PM CEST Brown, James 2 a écrit :That's right.
I need to find changed cells (removed and new) for moved vertices. TheWhen the Mesh Optimizers (from CGAL Mesh_3) do move vertices, the code needs
movement I have is fairly small but because some tetrahedra are very 'thin'
sometimes the points cross a face causing the tetrahedron to be in an
opposite orientation which would require the neighboring cells to be
retriangulated.
to have the same knowledge.
You may find what you need in the big collection of helper functions in <CGAL/
Mesh_3/C3T3_helpers.h>.
Moving a vertex implies :
- removing the old vertex : the new cells are the ones that triangulate the cavity formed by removing it
- inserting the position to a new vertex : the new cells are the cells incident to the new vertex
These groups of cells are not the same, and a union of them has to be done.
C3T3_helpers.h contains everything you need.
Best,
Jane Tournois, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- Re: [cgal-discuss] Changed cells in Delaunay_triangulation_3, Laurent Rineau (CGAL/GeometryFactory), 09/01/2016
- Re: [cgal-discuss] Changed cells in Delaunay_triangulation_3, Jane Tournois, 09/05/2016
- <Possible follow-up(s)>
- Re: [cgal-discuss] Changed cells in Delaunay_triangulation_3, Brown, James 2, 09/09/2016
- Re: [cgal-discuss] Changed cells in Delaunay_triangulation_3, Jane Tournois, 09/09/2016
- Re: [cgal-discuss] Changed cells in Delaunay_triangulation_3, Jane Tournois, 09/12/2016
