- To:
- Subject: Re: [cgal-discuss] Changed cells in Delaunay_triangulation_3
- Date: Thu, 01 Sep 2016 11:48:14 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:mp2FjhaT1jNyViqh4n0w8tT/LSx+4OfEezUN459isYplN5qZpcSybnLW6fgltlLVR4KTs6sC0LuP9f25EjRRqdbZ6TZZIcQKD0dEwewt3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9JIfegoyN2vyo/NWLOkMT1WP7POo5dET+7V2I8JJH2c06cud54yCKi0MAQ/5Ry2JsKADbtDfHzeD0wqRe9T9Nsekq7c9KXPayVa05SbtFEGZuaDhtt4W4/SXEGACA739ZXmQNmQdTGCDE6gv7V9H/qHjUrO14jWO+NNDsQLYoEQ6j6apiVVeoowguE3kW/WbSh9BqnYxSqw6mvQ0+icaAZIiILvd4YuXHfNUXTHdpVclYU2pGGIzqPNhHNPYIIesN99q1nFAJtxbrXQQ=
Le Wednesday, August 31, 2016 3:50:41 PM CEST Brown, James 2 a écrit :
> I need to find changed cells (removed and new) for moved vertices. The
> movement I have is fairly small but because some tetrahedra are very 'thin'
> sometimes the points cross a face causing the tetrahedron to be in an
> opposite orientation which would require the neighboring cells to be
> retriangulated.
When the Mesh Optimizers (from CGAL Mesh_3) do move vertices, the code needs
to have the same knowledge.
You may find what you need in the big collection of helper functions in <CGAL/
Mesh_3/C3T3_helpers.h>.
Laurent Rineau, PhD
- Re: [cgal-discuss] Changed cells in Delaunay_triangulation_3, Laurent Rineau (CGAL/GeometryFactory), 09/01/2016
- Re: [cgal-discuss] Changed cells in Delaunay_triangulation_3, Jane Tournois, 09/05/2016
- <Possible follow-up(s)>
- Re: [cgal-discuss] Changed cells in Delaunay_triangulation_3, Brown, James 2, 09/09/2016
- Re: [cgal-discuss] Changed cells in Delaunay_triangulation_3, Jane Tournois, 09/09/2016
- Re: [cgal-discuss] Changed cells in Delaunay_triangulation_3, Jane Tournois, 09/12/2016
