- To:
- Subject: Re: [cgal-discuss] Intersection between two sets of points in 3D space
- Date: Mon, 05 Sep 2016 12:53:42 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:9hOK1RVsjYZFNUyK8hSnpOACyz/V8LGtZVwlr6E/grcLSJyIuqrYZh2Bt8tkgFKBZ4jH8fUM07OQ6PG5HzFQqs3b+DBaKdoXBkdD0Z1X1yUbQ+e9QXXhK/DrayFoVO9jb3RCu0+BDE5OBczlbEfTqHDhpRQbGxH4KBYnbr+tQt2asc272qiI9oHJZE0Q3XzmMOo0cUX99l+Z9pFPx9AzcuBpklqBi0ALUtwe/XlvK1OXkkS0zeaL17knzR5tvek8/dVLS6TwcvdwZ7VZCDM7LzJ9v5Wz5lH1ZFDQvT5EDi1Wz0IJUED560TxUZ719yf7reFgwzKyPMvsTLlyVy7xwb1sTUqisyoNPiUl8WzRwuh3lqNcvFrhiBF4xoPIepC7PfFiebnMPJlSEXFFWdxQUDAHB4eUYI4GDu5HNuFd+dqu72ASpAezUFH/TNjkzSVF0yKu0A==
You can have a look at the surface reconstruction algorithms here:
http://doc.cgal.org/latest/Manual/packages.html#PartReconstruction
In particular, advancing front might be the one you are looking to
if you need to interpolate your input points.
Sebastien.
On 09/02/2016 10:20 PM, Vahid Azizi wrote:
Hi all,
I have two sets of points in 3D coordinate system, More precisely based
on my work one set is supposed to be a polyhedron or a complex volume
and one set is just a 3D convex hull. I have only the coordinates of the
points. and finally i want to find their bounded intersection. what
would you suggest for handling this problem? do i need to make a
polyhedron or triangles from first set or there is other options? and
what would you suggest for intersection? Any general information, links,
tips are appreciated.
Thank you so much in advance.
Best,
/Vahid/
- [cgal-discuss] Intersection between two sets of points in 3D space, Vahid Azizi, 09/02/2016
- Re: [cgal-discuss] Intersection between two sets of points in 3D space, Sebastien Loriot (GeometryFactory), 09/05/2016
- Re: [cgal-discuss] Intersection between two sets of points in 3D space, Vahid Azizi, 09/05/2016
- Re: [cgal-discuss] Intersection between two sets of points in 3D space, Sebastien Loriot (GeometryFactory), 09/06/2016
