Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation
- To:
- Subject: Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation
- Date: Mon, 05 Sep 2016 12:48:41 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:PWRCtx9C4B4W2/9uRHKM819IXTAuvvDOBiVQ1KB+2uMcTK2v8tzYMVDF4r011RmSDNydtqIP0bue8/i5HzdfsdDZ6DFKWacPfiFGoP1epxYnDs+BBB+zB9/RRAt+Iv5/UkR49WqwK0lfFZW2TVTTpnqv8WxaQU2nZkImbtjyT4XdhsDy2+Gp8IDIeC1JgiC8aPV8NkaYtwLU44MtjIFrMbowxx2BhnxSeuNKjSNHKFWWkgrm9+m594Jk6TUR8bp17MpHS6T9Y+I9SZRXCT0nNyY+48i95kqLdheG+nZJCjZeqRFPGQWQtBw=
Could you provide a full example reproducing the issue?
Thanks,
Sebastien.
On 09/02/2016 07:24 PM, Sukhraj Singh wrote:
Hello,
I am trying to create a particular segment (which is the output of
surface mesh segmentation) as ROI in Surface Mesh Deformation.
I implemented following code, which is crashing( psb comment below)
void set_all_vertices_as_roi()
vertex_iterator vb, ve;
for(boost::tie(vb, ve) = vertices(*polyhedron()); vb != ve; ++vb)
insert_roi_vertex(*vb);
//Implement it likewise all mesh vertices as roi
void set_segment_vertices_as_roi(Polyhedron mesh)
std::size_t number_of_clusters;
double smoothing_lambda ;
// create a property-map for segment-ids
typedef std::map<Polyhedron::Facet_const_handle, std::size_t>
Facet_int_map;
Facet_int_map internal_segment_map;
boost::associative_property_map<Facet_int_map>
segment_property_map(internal_segment_map);
//Run the sdf segmentation algo
int nb_segments =
SegmentPolyhedron(segment_property_map,number_of_clusters, smoothing_lambda
,mesh);
std::vector <Polyhedron> PolySegments;
PolySegments.resize(nb_segments);
//Get the segement of the mesh
GetSegments(mesh,segment_property_map,nb_segments,PolySegments,0);
//Make zeroth segment as ROI
for(boost::tie(vb, ve) = vertices(PolySegments[0]); vb != ve;
++vb)
//std::cout << __LINE__ << std::endl;
insert_roi_vertex(*vb); // GIVES CRASH
Perhaps it is because of size of deform_mesh, which was equal to
complete non-segmented mesh size. ?
There is k-ring selection as well, which is used when picked by mouse.
Can someone suggest me some other way maybe, so that I could make the
mesh segment as ROI
Thanks to provide input.
Sukhraj Singh
- [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sukhraj Singh, 09/02/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sebastien Loriot (GeometryFactory), 09/05/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sukhraj Singh, 09/05/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sebastien Loriot (GeometryFactory), 09/06/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sukhraj Singh, 09/07/2016
- Re: [cgal-discuss] Creating a surface mesh segment as the ROI in Surface mesh deformation, Sebastien Loriot (GeometryFactory), 09/07/2016
