- To:
- Subject: Re: [cgal-discuss] add 0-d features
- Date: Thu, 08 Sep 2016 09:30:45 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:zqMTDBwmbnUp2BLXCy+O+j09IxM/srCxBDY+r6Qd0ekVIJqq85mqBkHD//Il1AaPBtSCrawewLKM++C4ACpbvsbH6ChDOLV3FDY7yuwu1zQ6B8CEDUCpZNXLVAcdWPp4aVl+4nugOlJUEsutL3fbo3m18CJAUk6nbVk9dazIHJXPhZG3y/yq4M+UJB5ZgSK0J7J0NhS/6wvL8dIHhJNrbac3xByOqXRBf6FaxHhjOEmIzCr7s8y/9Zom/yVLsO867OZBV7/7duI2V+92FjMjZkY078rcjhLDSZWK62FUBmMXmR0OGAPF6Bb3W5rrmiT/v+t5niKdOJulHvgPRT2+4vIzG1fTgyAdOmth/Q==
Thanks Jane for the reply!
I've checked out the example [1] but didn't find it very enlightening. `random_labeled_image()`, `initialize_triangulation_from_labeled_image`? Perhaps a wrong link.
Cheers,
Nico
Hi Nico,
the functions that are available so far only allow to add polyline-features.
In CGAL-4.9-beta1 [1], we have published an example showing how to
customize the initialization of the meshing process [2].
Using the same framework, you can add a 0-d feature by inserting a
weighted point at the tip of your cone. This way you can make sure it
will be present in the output mesh.
Best,
Jane
[1] http://www.cgal.org/2016/08/04/cgal49-beta1/
[2]
http://doc.cgal.org/4.9/Mesh_3/Mesh_3_2mesh_3D_image_with_custom_initialization_8cpp-example.html
Le 30/08/2016 à 12:27, Nico Schlömer a écrit :
> Hi everyone,
> I'd like to mark the tip of a cone as a 0-dimensional feature; how to
> do that? So far, I've only found 1D-feature addition [1].
> Cheers,
> Nico
> [1]
> http://doc.cgal.org/latest/Mesh_3/classCGAL_1_1Mesh__domain__with__polyline__features__3.html#a2e99457765c639ab583d2dd1057160ea
Jane Tournois, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- Re: [cgal-discuss] add 0-d features, Jane Tournois, 09/08/2016
- Re: [cgal-discuss] add 0-d features, Nico Schlömer, 09/08/2016
