- To:
- Subject: Re: [cgal-discuss] add 0-d features
- Date: Thu, 8 Sep 2016 16:12:39 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:1xN1JR8l6KWYo/9uRHKM819IXTAuvvDOBiVQ1KB80e8cTK2v8tzYMVDF4r011RmSDNydtagP1Lae8/i5HzdRudDZ6DFKWacPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvjotuNOU4X2HL9Oeo0d0Tu612J94E/ushLEu4J0BzHo39FKax95FhDAhatpSv6/dq655V58i5d6LoL/s9EVrjmLexjFeQLRGduDmYu+ce+tQXfVRDdoTwHQ2AOm1xJBRLE5Vf0RNDqoy7iv6183iedesb5RLRxVTW55LpwU0zUj3IMODc9tW3Wkcdtl7lzoRS7phU5zZSHTpuSMa9cd6XQNe8dWHBHWcdKH3hDC4WxKZcIEvAHOudDh4bwoF4DsQGvCwCnGOT123lDgXqgjv5y6PgoDQyThF9oJNkJqnmB9Ng=
Yes, the one I sent you. You need to dig in the example files of Mesh_3 to find the associated .h file Jane. Le 08/09/2016 à 15:51, Nico Schlömer a
écrit :
> So, the function
`initialize_triangulation_from_labeled_image` is
the function you need to replace with your own initialization
procedure.
Aha! Is there an example for a custom initialization
available?
Cheers,
Nico
On Thu, Sep 8, 2016 at 3:48 PM Jane Tournois <>
wrote:
Hi Nico, The basic meshing algorithm is : - initialize the triangulation with a small number of
points to help the refinement process start The protection of features is a part of the initialization procedure, and you can decide to make your own initialization by following the same framework as this example. So, the function `initialize_triangulation_from_labeled_image` is the function you need to replace with your own initialization procedure. It requires inserting the feature vertices as weighted points, maybe also protect some polylines, and basically put some points on important areas of the object to be meshed. Hope it helps, Jane. Le 08/09/2016 à 11:30, Nico Schlömer a écrit :
-- Jane Tournois, PhD R&D Engineer at GeometryFactory http://www.geometryfactory.com/ -- Jane Tournois, PhD R&D Engineer at GeometryFactory http://www.geometryfactory.com/ |
- Re: [cgal-discuss] add 0-d features, Jane Tournois, 09/08/2016
- Re: [cgal-discuss] add 0-d features, Nico Schlömer, 09/08/2016
