- To:
- Subject: [cgal-discuss] Parallel computing for 3D Surface Mesh Generation
- Date: Tue, 13 Sep 2016 11:00:56 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:mzqYeR104Hpeca9nsmDT+DRfVm0co7zxezQtwd8ZsegQK/ad9pjvdHbS+e9qxAeQG96KsrQb06GM6uigATVGusfZ9ihaMdRlbFwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oMyKJVoQz2DkKfMqdVPt/F2X7pFXyaJZaY8JgiPTpXVJf+kEjUhJHnm02yjG28Gr4ZR4+D5Rsf9yv+RJUKH9YrhqBecAVGduYCgJ45jguhDHCAeO/XABSX4+kxxSAgGD4gupcI32t37Av+/m3mGxNNb7V7d8cj075rwjHAXjgTwKLTkR/2Tei8g2h6Ve9kHy7ydjypLZNdnGfMF1ebnQKIsX
Hi all,
I have a little function to generate a surface mesh using CGAL::make_surface_mesh as described in the documentation
Is it possible to enable parallel computing for this function?
Currently I use for the triangulation
typedef CGAL::Surface_mesh_default_triangulation_3 Tr;
which doesn't have an option for the CGAL::Parallel_tag.
Is there a way to replace CGAL::Surface_mesh_default_triangulation_3 by another type that takes the parallel tag?
When I search, I find how to do it for volumetric meshes
but I'm not sure how to go to surface meshes.
Best regards,
Ramon.
Dr. Ramón Casero Cañas
Institute of Biomedical Engineering
Department of Engineering Science, University of Oxford
Old Road Campus Research Building, Headington
Oxford
OX3 7DQ
UK
tlf +44 (0) 1865 617716
twitter @Ramon_Casero
web http://www.cs.ox.ac.uk/people/Ramon.CaseroCanas/
Oxford
OX3 7DQ
UK
- [cgal-discuss] Parallel computing for 3D Surface Mesh Generation, Ramón Casero Cañas, 09/13/2016
- Re: [cgal-discuss] Parallel computing for 3D Surface Mesh Generation, Jane Tournois, 09/13/2016
- Re: [cgal-discuss] Parallel computing for 3D Surface Mesh Generation, rcasero, 09/13/2016
