- To:
- Subject: Re: [cgal-discuss] Parallel computing for 3D Surface Mesh Generation
- Date: Tue, 13 Sep 2016 14:15:09 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:M67f2hOFjPnr1En3Ts0l6mtUPXoX/o7sNwtQ0KIMzox0K/TyrarrMEGX3/hxlliBBdydsKMdzbWO+Py+ESxYuNDa7yBEKMQNHzY+yuwo3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9ScbuiJG82Om2vpHSeA5VnyGVYLVoLRzwox+CmNMRhN5AI6A8gifOv2FOfOVNjTdqLFSe2Qr7+922+5942ytdvPcs69RRX6zxY6MiXPpTCzFwYDN939HiqRSWFVjH3XAbSGhDyhc=
Hi Ramon, there is an example in CGAL-4.9 to help you do what you want. http://doc.cgal.org/4.9/Mesh_3/Mesh_3_2remesh_polyhedral_surface_8cpp-example.html Jane. Le 13/09/2016 à 12:00, Ramón Casero
Cañas a écrit :
Hi all,
I have a little function to generate a surface mesh
using CGAL::make_surface_mesh as described in the
documentation
http://doc.cgal.org/latest/Surface_mesher/index.html
Is it possible to enable parallel computing for this
function?
Currently I use for the triangulation
typedef CGAL::Surface_mesh_default_triangulation_3 Tr;
which doesn't have an option for the CGAL::Parallel_tag.
Is there a way to
replace CGAL::Surface_mesh_default_triangulation_3 by
another type that takes the parallel tag?
When I search, I find how to do it for volumetric meshes
http://doc.cgal.org/latest/Mesh_3/
but I'm not sure how to go to surface meshes.
Best regards,
Ramon.
Dr. Ramón Casero Cañas
Institute of Biomedical Engineering Department of Engineering Science, University of Oxford Old Road Campus Research Building, Headington Oxford OX3 7DQ UK tlf +44 (0) 1865 617716 twitter @Ramon_Casero web http://www.cs.ox.ac.uk/people/Ramon.CaseroCanas/ -- Jane Tournois, PhD R&D Engineer at GeometryFactory http://www.geometryfactory.com/ |
- [cgal-discuss] Parallel computing for 3D Surface Mesh Generation, Ramón Casero Cañas, 09/13/2016
- Re: [cgal-discuss] Parallel computing for 3D Surface Mesh Generation, Jane Tournois, 09/13/2016
- Re: [cgal-discuss] Parallel computing for 3D Surface Mesh Generation, rcasero, 09/13/2016
