- To:
- Subject: Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal
- Date: Thu, 22 Sep 2016 12:31:22 -0700 (PDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:buQPNBb9HRSQ/WHaTIAR4YP/LSx+4OfEezUN459isYplN5qZpc+6bnLW6fgltlLVR4KTs6sC0LuM9fi8EjVbvt6oizMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JXtkbjusMSIPE1hv3mUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqrze+E0TKdTES89G2Ez/szi8xfZHiWV4X5JWWUMkwFNS1zO7Av7RdH0uzHhtsJgwyCBPov9ROZnCnyZ8653RUqw2288PDkj/TSPhw==
Hi,
This is what I'm doing now. It is a less clean solution than using the
lat/long coords directly.
I'm still unclear why this is occurring?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Re-Wrong-unit-normal-with-CGAL-unit-normal-tp4662294p4662295.html
- [cgal-discuss] Wrong unit normal with CGAL::unit_normal, chrism, 09/12/2016
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, Sebastien Loriot (GeometryFactory), 09/12/2016
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, chrism, 09/12/2016
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, Sebastien Loriot (GeometryFactory), 09/13/2016
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, chrism, 09/13/2016
- <Possible follow-up(s)>
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, Brown, James 2, 09/22/2016
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, chrism, 09/22/2016
- AW: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, Becker, Hans-Ulrich, 09/23/2016
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, chrism, 09/23/2016
