- To: "" <>
- Subject: AW: [cgal-discuss] Wrong unit normal with CGAL::unit_normal
- Date: Fri, 23 Sep 2016 14:11:37 +0200
- Accept-language: de-DE
- Acceptlanguage: de-DE
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23:CqqdcRE0vKG8emaZSaMEaJ1GYnF86YWxBRYc798ds5kLTJ75pcywAkXT6L1XgUPTWs2DsrQf2rCQ6/+rBT1Ioc7Y9itdINoUD15NoP5VtjJjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScaBx/iwgqq59JTXJglJnzGgeqhaLROsrAyXuNNcyd9pJa81jxfIuXBVYP9+xGVyJFvVkQyqtemq+5s2uQ5dsPEs7YoIcaz8ZOEFSaZZBzRsezQV7cvw8CTHVwqE5j02X24VnwBgGBTf/RL3RNH6tS6s5bk14zWTIcCjFeN8Yj+l9ao+EBI=
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
Hi Mike,
it's stupid, but it seems to me that the problem is caused by the additional planar face which intersects both the bone on both sides:
Some months ago I had a similar problem by a model provided by Vlad, so the (‘implicit’) requirement was that the planar face should only intersect the ‘correct’ side of the bone, it is the side of the bone where the implant is located. Here that means that we have to move the planar face in x-direction so that there is only one closed bone/planar face intersection … I’m pretty sure that that will help to get the correct result. You know: This solution is a rough prototype: I will spend some more time on the final solution to get it really stable ….
Sorry for all this additional effort and enjoy your weekend Ulli
-----Ursprüngliche Nachricht-----
Crap, I hadn't even considered the implications of that for calculating a normal.
Thanks very much!
-- View this message in context: http://cgal-discuss.949826.n4.nabble.com/Re-Wrong-unit-normal-with-CGAL-unit-normal-tp4662294p4662297.html Sent from the cgal-discuss mailing list archive at Nabble.com.
-- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://sympa.inria.fr/sympa/info/cgal-discuss
Description: add_bone_intersection.PNG
- [cgal-discuss] Wrong unit normal with CGAL::unit_normal, chrism, 09/12/2016
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, Sebastien Loriot (GeometryFactory), 09/12/2016
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, chrism, 09/12/2016
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, Sebastien Loriot (GeometryFactory), 09/13/2016
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, chrism, 09/13/2016
- <Possible follow-up(s)>
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, Brown, James 2, 09/22/2016
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, chrism, 09/22/2016
- AW: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, Becker, Hans-Ulrich, 09/23/2016
- Re: [cgal-discuss] Wrong unit normal with CGAL::unit_normal, chrism, 09/23/2016
