cgal-discuss - [cgal-discuss] Mesh segmentation: Why is number_of_segments==number_of faces on any model?
  • To:
  • Subject: [cgal-discuss] Mesh segmentation: Why is number_of_segments==number_of faces on any model?
  • Date: Fri, 18 Nov 2016 13:41:26 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hello ,
I am trying to segment a polyhedron using the following code:
 void meshSegmentation()
        std::cout<<"Segmenting Mesh.."<<std::endl;
        using Facet_int_map=std::map<CGALPolyhedron::Facet_const_handle,std::size_t>;
        Facet_int_map internal_segment_map;
        boost::associative_property_map<Facet_int_map> segment_property_map(internal_segment_map);
        std::size_t number_of_segments=CGAL::segmentation_via_sdf_values(P,segment_property_map);
        std::cout<<"Number of segments: "<<number_of_segments<<std::endl;
        std::cout<<"Segmentation finished."<<std::endl;
(I have previously checked that the P.is_valid()==1)
Why is the number of segments always equal to the number of faces?
