- To:
- Subject: Re: [cgal-discuss] Building and installing from source on CentOS 7
- Date: Fri, 18 Nov 2016 04:07:46 -0800 (PST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
I resolved the problem by using this Docker file as an example:
https://github.com/CGAL/cgal-testsuite-dockerfiles/blob/master/CentOS-7/Dockerfile
Still not sure exactly what the problem was.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Building-and-installing-from-source-on-CentOS-7-tp4662365p4662367.html
- [cgal-discuss] Building and installing from source on CentOS 7, ralenhlaalo, 11/16/2016
- Re: [cgal-discuss] Building and installing from source on CentOS 7, ralenhlaalo, 11/18/2016
- Re: [cgal-discuss] Building and installing from source on CentOS 7, Daniel Duque, 11/18/2016
