- To:
- Subject: Re: [cgal-discuss] Transform only specific vertices of a Polyhedron_3
- Date: Fri, 2 Dec 2016 15:45:19 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
You can do vertex_handle->point() = vertex_handle->point().transform(...) since vertex.point() returns a reference type.
On Fri, Dec 2, 2016 at 3:21 PM, SirM2X <> wrote:
Anyone...?
I feel there is an easy way to transform the vertices of a polyhedron
in-place, and I'm missing it...
There is /vertex.point.transform()/ but, it returns a new point, and I'm not
sure if I can modify the original vertex with this transformed point... :(
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Transform-only-specific-vertices-of-a-Polyhedron-3-tp4662402p4662410.html
- Re: [cgal-discuss] Transform only specific vertices of a Polyhedron_3, SirM2X, 12/02/2016
- Re: [cgal-discuss] Transform only specific vertices of a Polyhedron_3, Pádraig Ó Conbhuí, 12/02/2016
