- To:
- Subject: Re: [cgal-discuss] Transform only specific vertices of a Polyhedron_3
- Date: Fri, 2 Dec 2016 16:21:30 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:yegePh28oFhJrqfZsmDT+DRfVm0co7zxezQtwd8ZsegVKPad9pjvdHbS+e9qxAeQG96KsLQY0KGK6+igATVGusnR9ihaMdRlbFwst4Y/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbre9J4jJks7i1/yu44aBJEJTlT+laPVzKg+3pEPfrI4NkI56I+EwzBXO5XBHcuATyWJzLk+IhEXA4ZK785dntihRoPk87NVoUKPgfq1+Q6YLIi4hNjUNbcHxvBjMBbDHzXwaWGULF1IcGw/O6xfwXorwmiT/v+t5niKdOJulHvgPRT2+4vIzG1fTgyAdOmth/Q==
Maybe if you get the vertex from the HalfedgeDS object using a Modifier_base class instead of from the polyhedron?
On Fri, Dec 2, 2016 at 3:54 PM, SirM2X <> wrote:
Thanks for your response...
Although that works, it gives me the exact results as the one which I posted
the pseudocode for...
Somehow I have a feeling that once the points are assigned, the polygon's
faces are not updated, or are messed up somehow.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Transform-only-specific-vertices-of-a-Polyhedron-3-tp4662402p4662412.html
- Re: [cgal-discuss] Transform only specific vertices of a Polyhedron_3, SirM2X, 12/02/2016
- Re: [cgal-discuss] Transform only specific vertices of a Polyhedron_3, Pádraig Ó Conbhuí, 12/02/2016
